Staples 34462 Electric Pencil Sharpener Cutter Replacement
    1. Staples 34462 Electric Pencil Sharpener Cutter Replacement, Cover: step 1, image 1 of 1
      • Pull out the shavings tray from the pencil sharpener.
      • Beware of loose pencil shavings falling on your workspace.
      Ask FixBot
    2. Staples 34462 Electric Pencil Sharpener Cutter Replacement: step 2, image 1 of 1
      • Turn the pencil sharpener on its side.
      Ask FixBot
    3. Staples 34462 Electric Pencil Sharpener Cutter Replacement: step 3, image 1 of 1
      • Using a Phillips00 screwdriver, remove the two front 11.6mm screws.
      • Using the plastic opening tool, remove the back plastic feet.
      • After removing the back plastic feet, using a Phillips 00 screwdriver, remove the two back 11.6mm screws.
      • The hole is deeper than you may think. It may take some time to get the screwdriver to click in.
      Ask FixBot
    4. Staples 34462 Electric Pencil Sharpener Cutter Replacement: step 4, image 1 of 1
      • Carefully pull apart the bottom panel from the top panel.
      • Be careful not to pull too forcefully as the panels are connected by wires.
      • Beware of pencil shavings falling out onto your workspace.
      Ask FixBot
    5. Staples 34462 Electric Pencil Sharpener Cutter Replacement: step 5, image 1 of 1
      • Using a Phillips00 screwdriver, remove two 8.9mm flat edge screws from the top section of the top panel.
      Ask FixBot
    6. Staples 34462 Electric Pencil Sharpener Cutter Replacement: step 6, image 1 of 1
      • Using a Phillips00 screwdriver, remove two 10.3mm screws from the middle section of the top panel.
      Ask FixBot
    7. Staples 34462 Electric Pencil Sharpener Cutter Replacement: step 7, image 1 of 1
      • Carefully pull the cover from the top panel and set it aside.
      Ask FixBot
    1. Staples 34462 Electric Pencil Sharpener Cutter Replacement, Cutter: step 8, image 1 of 1
      • Orient the top panel so that the sensor bracket is facing you.
      • Using a Phillips00 screwdriver, remove four 10.42mm screws.
      • Using a Phillips00 screwdriver, remove two 6.96mm screws.
      Ask FixBot
    2. Staples 34462 Electric Pencil Sharpener Cutter Replacement: step 9, image 1 of 1
      • Pull out the outside cover to remove it from the cutter chamber and set them side by side.
      Ask FixBot
    3. Staples 34462 Electric Pencil Sharpener Cutter Replacement: step 10, image 1 of 1
      • Carefully pull the cutter out of the cutter chamber.
      • Beware of pencil shavings and debris.
      Ask FixBot
4 Guide Comments
Very clear, easy to follow. Nice photos.
uccbill - Reply Share
where can I get a replacement cutter?
Mel Buchanan - Reply Share
Did you find replacement blades?
Horace M Hargroves - Reply Share
Absolutely great directions. However I lost the two 10.3mm screws somewhere along the line - I did not go any further at that point. I will check out replacement cutters and see if I want to pursue or purchase new. I believe this was my work stapler of the 80's.
Leslie H - Reply Share
Past 24 Hours: 8
Past 7 Days: 30
Past 30 Days: 70
All Time: 3,491
