Introduction
Go to step 1 ↓If your stapler isn’t stapling, then there’s a good chance the spring is damaged. This guide's purpose is to assist users in replacing the stapler spring.
If you don’t replace the spring yourself, you’ll either have a broken stapler cluttering up your work space or will end up buying a new stapler altogether.
Before using this guide, check to see if the spring itself is damaged. Another possibility of a stapler not working is a staple jam. Be careful when handling the stapler, since it’s possible to staple yourself. We recommend that you empty the staples beforehand.
16 other people completed this guide.
14 Guide Comments
Just what I needed. Thank you! Super clear
Wie funktioniert das für große Klammermaschinen wie dieser hier?
Where do I obtain a replacement spring for this stapler?
