Up to 20% off select tools
Stapler Maintenance
Views: 68K
View statistics:
Past 24 Hours:
55
Past 7 Days:
492
Past 30 Days:
2,417
All Time:
68,326
Comments: 3
3 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 seconds - 1 minute
Difficulty: Moderate
Community-Contributed Guide
Stapler Maintenance
Introduction
Go to step 1 ↓
Use this guide to refill and empty stapler, so you can get back to those TPS reports.
    1. Stapler Maintenance, Open & Identify: step 1, image 1 of 2 Stapler Maintenance, Open & Identify: step 1, image 2 of 2
      • Be careful while handling staples or any sharp object in general.
      • Grab the base of the stabler, and pull the hammer until the stapler opens, revealing the carrier, pusher, and spring.
      • Identify the staple type by looking on the bottom of the carrier. If the staple type is not on the carrier, look under the base.
      Ask FixBot
    2. Stapler Maintenance, Insert Staples: step 2, image 1 of 2 Stapler Maintenance, Insert Staples: step 2, image 2 of 2
      • Get a cluster of staples and carefully place it in the carrier.
      • Make sure there is enough room for the pusher to contact the staples.
      • Close the stapler by clearing your hand from under the crimp area and pushing the hammer down until a clicking sound is heard.
      Ask FixBot
    3. Stapler Maintenance: step 3, image 1 of 1
      • Don’t staple your hand, or anyone else for that matter.
      • Congratulations! You have successfully replaced staples in your stapler.
      Ask FixBot
10 other people completed this guide.
Author
with
Sequoia Equities
279 Reputation
1 Guide authored
3 Guide Comments
Wnen I tried to load the staples, the spring came loose. But I do not know where to reconnect it and have a loose short plastic rod!
Brian Gray - Reply Share
@ cookie clicker When I attempted to load the staples, the spring became detached. However, I'm unsure where to reattach it, and I now have a loose, short plastic rod.
Nadia Eira - Reply Share
I got it
thank you bro, for sharing it
freakcircus - Reply Share
Past 24 Hours: 55
Past 7 Days: 492
Past 30 Days: 2,417
All Time: 68,326
