Up to 20% off select tools
Stanley 10-079 Box Cutter Blade Replacement
Views: 8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
35
Past 30 Days:
201
All Time:
8,049
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 50 seconds - 5 minutes
Difficulty: Very easy
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the blade on a Stanley 10-079 Box Cutter.
    1. Stanley 10-079 Box Cutter Blade  Replacement, Knife Blade: step 1, image 1 of 1
      • Here is the knife we will be replacing the blade on, its a Stanley 10-079 Box Cutter.
      Ask FixBot
    2. Stanley 10-079 Box Cutter Blade  Replacement: step 2, image 1 of 1
      • Using a screwdriver or a coin remove the single screw in the center of the box cutter
      Ask FixBot
    3. Stanley 10-079 Box Cutter Blade  Replacement: step 3, image 1 of 1
      • Carefully pull up on the top half of the cutter exposing the blade on the inside.
      Ask FixBot
    4. Stanley 10-079 Box Cutter Blade  Replacement: step 4, image 1 of 1
      • carefully without cutting yourself lift the old blade out this should require no force.
      Ask FixBot
    5. Stanley 10-079 Box Cutter Blade  Replacement: step 5, image 1 of 1
      • with the old blade out replace it with a new blade from the back or one that was purchased separately.
      Ask FixBot
    6. Stanley 10-079 Box Cutter Blade  Replacement, Reassembly: step 6, image 1 of 2 Stanley 10-079 Box Cutter Blade  Replacement, Reassembly: step 6, image 2 of 2
      • With the fresh blade in place carefully place the upper half of the box cutter on the lower half that contains the blade as shown in image number 2.
      Ask FixBot
    7. Stanley 10-079 Box Cutter Blade  Replacement, Final Assembily: step 7, image 1 of 1
      • insert the screw you first removed back into the hole in the center ensuring that you tighten it down not too tight to get undone without a power tool
      Ask FixBot
    8. Stanley 10-079 Box Cutter Blade  Replacement: step 8, image 1 of 1
      • With the center screw re-installed you are all set to use your Stanley 10-079 box cutter again with a brand new blade.
      Ask FixBot
You are all set and ready to use your brand new installed blade! Here are some replacement blades that I found on amazon. https://www.amazon.com/Stanley-11-921L-5...
2 other people completed this guide.
Author
with
Michael Cawley
184 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 35
Past 30 Days: 201
All Time: 8,049
