Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓This guide will go over replacing a Fender Squier Stratocaster standard tuner. Typically, a loose tuner will cause tuning issues, and can render the guitar unplayable. Typically, when a tuner is unable to remain tight and keep a string in tune, it is time to replace it. It is, in some cases, possible to repair a loose or broken tuner, however that is outside of the scope of this guide.
* If you are replacing the standard Fender Squier Stratocaster tuner with an aftermarket, or different Fender tuner model, this guide may not be applicable due to variance in tuner mechanisms and styles.
Tools
Loosen the string for the tuner you are replacing until there is a lot of slack in the string.
Once you have tightened the replacement tuners nut, the guitar is ready to restring. Congratulations, you have successfully replaced a Fender Squier Stratocaster tuner!
