Up to 20% off select tools
Spy Net Ultra Vision Goggles Microphone Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
95
All Time:
975
Comments: 0
Go to guide comments
Completed: 0
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Before we begin taking apart the device, make sure that you have visited the Troubleshooting Page in order to verify that the problem with the device is in fact a faulty microphone.
    1. Spy Net Ultra Vision Goggles Microphone Replacement, Open the Device: step 1, image 1 of 1
      • Using the screwdriver, remove the six silver 11.4 mm Phillips #0 screws that hold the device shell in place.
      • Pull apart the back of the device, using the plastic opening tool if needed. To do this, locate the groves running along the side of the entire device and wedge it open.
      Ask FixBot
    2. Spy Net Ultra Vision Goggles Microphone Replacement, Un-Solder the Wiring from the Circuit Board: step 2, image 1 of 1
      • Find the connection of the red and black wires to the circuit board behind the LED screen.
      • Un-solder the wires from the board using the soldering iron.
      • Need Help Soldering? Check out How To Solder and Desolder Connections
      Ask FixBot
    3. Spy Net Ultra Vision Goggles Microphone Replacement, Un-Solder the Microphone: step 3, image 1 of 1
      • Find the connection of the red and black wires to the funnel-shaped lens cover.
      • Un-solder the wires from the microphone using the soldering iron.
      • Remove the red and black wires from the device and solder on the replacement.
      Ask FixBot
Author
with
Justin Diehl
66 Reputation
1 Guide authored
USF Tampa, Team 4-5, Brown Fall 2014 Member of USF Tampa, Team 4-5, Brown Fall 2014
USFT-BROWN-F14S4G5
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 95
All Time: 975
