Up to 20% off select tools
Spy Net Ultra Vision Goggles Lens Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
103
All Time:
1,189
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
If when looking through the the goggles the image is blurred or distorted there is a chance this is due to a smudged or damaged lens. This guide will illustrate how to remove the lens to clean or replace it. For more information on smudged or damaged lens refer to the troubleshooting page. Link:Spy Net Ultra Vision Goggles Troubleshooting
    1. Spy Net Ultra Vision Goggles Lens Replacement, Opening the Device: step 1, image 1 of 2 Spy Net Ultra Vision Goggles Lens Replacement, Opening the Device: step 1, image 2 of 2
      • Remove the six silver 11.4 mm Phillips #0 screws and pry open the device, using the plastic opening tools if necessary. To do this, locate the groves running along the side of the entire device and wedge it open.
      Ask FixBot
    2. Spy Net Ultra Vision Goggles Lens Replacement, Remove the Lens Housing: step 2, image 1 of 2 Spy Net Ultra Vision Goggles Lens Replacement, Remove the Lens Housing: step 2, image 2 of 2
      • Once the device is open, remove the lens tunnel, then twist the lens to unscrew it from the camera.
      Ask FixBot
    3. Spy Net Ultra Vision Goggles Lens Replacement: step 3, image 1 of 2 Spy Net Ultra Vision Goggles Lens Replacement: step 3, image 2 of 2
      • Remove the two black 7.15 mm Phillips #00 screws from the lens.
      • Once the screws are out, the lens casing should pull apart.
      Ask FixBot
Author
with
Andrew Gittens
143 Reputation
4 Guides authored
USF Tampa, Team 4-5, Brown Fall 2014 Member of USF Tampa, Team 4-5, Brown Fall 2014
USFT-BROWN-F14S4G5
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 103
All Time: 1,189
