Sprout channel cubby outer trim Replacement
    1. Sprout channel cubby outer trim Replacement, Dissasemble the device: step 1, image 1 of 2 Sprout channel cubby outer trim Replacement, Dissasemble the device: step 1, image 2 of 2
      • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
      • It is easiest to start on the corners.
      Ask FixBot
    1. Sprout channel cubby outer trim Replacement, outer trim: step 2, image 1 of 2 Sprout channel cubby outer trim Replacement, outer trim: step 2, image 2 of 2
      • There are 19 tabs that need to be pushed out of the inner trim. The metal spudger works great here.
      • Do not push too hard on the tabs or they will break.
      Ask FixBot
jasen biggins
741 Reputation
5 Guides authored
USF Tampa, Team 14-101, Meier Fall 2015 Member of USF Tampa, Team 14-101, Meier Fall 2015
USFT-MEIER-F15S14G101
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 106
All Time: 877
