Sprout Channel Cubby Speaker Replacement
    1. Sprout Channel Cubby Speaker Replacement, Dissasemble the device: step 1, image 1 of 2 Sprout Channel Cubby Speaker Replacement, Dissasemble the device: step 1, image 2 of 2
      • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
      • It is easiest to start on the corners.
      Ask FixBot
    1. Sprout Channel Cubby Speaker Replacement, Speaker: step 2, image 1 of 2 Sprout Channel Cubby Speaker Replacement, Speaker: step 2, image 2 of 2
      • While using the spatula, slowly get under the top part of the speaker. Then slowly move down the speaker to detach it from the device (there is a small amount of adhesive).
      Ask FixBot
    2. Sprout Channel Cubby Speaker Replacement: step 3, image 1 of 2 Sprout Channel Cubby Speaker Replacement: step 3, image 2 of 2
      • Remove black tape.
      • Disconnect the red and black wires which are soldered to the device. Make sure to not remove the wires that connect to the battery.
      • Replace the speaker.
      • Follow the steps in reverse order (be sure to solder the wires correctly) to install it.
      Ask FixBot
jasen biggins
741 Reputation
5 Guides authored
USF Tampa, Team 14-101, Meier Fall 2015 Member of USF Tampa, Team 14-101, Meier Fall 2015
USFT-MEIER-F15S14G101
4 Members
72 Guides authored
2 Guide Comments
Jasen, where can I purchase the replacement speaker for the Sprout?
william mulligan - Reply Share
There is no way that I would want to take apart a new tablet to replaceor repair the speakers. Why not install it correctly the first time? Appears to be an ongoing issue.
Edreia Jones - Reply Share
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 99
All Time: 1,726
