Up to 20% off select tools
Sprout Channel Cubby Digitizer Replacement
Views: 4.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
105
All Time:
4,578
Comments: 8
4 comments on steps, 4 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 20 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
When the screen cracks but keeps displaying video, the digitizer (cover glass) needs replaced. The screen and the digitizer are extremely fragile and should be taken out with extreme care.
    1. Sprout Channel Cubby Digitizer Replacement, Dissasemble the device: step 1, image 1 of 2 Sprout Channel Cubby Digitizer Replacement, Dissasemble the device: step 1, image 2 of 2
      • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
      • It is easiest to start on the corners.
      Ask FixBot
    1. Sprout Channel Cubby Digitizer Replacement, Digitizer: step 2, image 1 of 1
      • Once opened, carefully peel back the black electric tape around the digitizer.
      Ask FixBot
    2. Sprout Channel Cubby Digitizer Replacement: step 3, image 1 of 1
      • Unclasp the electrical plastic strip by gently pulling up on the white colored clasp.
      Ask FixBot
    3. Sprout Channel Cubby Digitizer Replacement: step 4, image 1 of 1
      • Unscrew the five screws holding down the motherboard.
      Ask FixBot
    4. Sprout Channel Cubby Digitizer Replacement: step 5, image 1 of 1
      • Once all five screws are removed, you should be able to lift up the motherboard.
      Ask FixBot
    5. Sprout Channel Cubby Digitizer Replacement: step 6, image 1 of 1
      • Remove the four remaining screws.
      • This can be done with the battery still attached but is easier if it is unattached.
      Ask FixBot
    6. Sprout Channel Cubby Digitizer Replacement: step 7, image 1 of 1
      • Remove the metal sheet covering the screen and digitizer.
      • Removing the screen is a very fragile process and needs to be done slowly. The nylon spudger is the best tool for this.
      Ask FixBot
    7. Sprout Channel Cubby Digitizer Replacement: step 8, image 1 of 2 Sprout Channel Cubby Digitizer Replacement: step 8, image 2 of 2
      • Remove all of the white pegs located along the perimeter of the plastic. You'll need to remove all of the pegs to remove the white front face.
      Ask FixBot
    8. Sprout Channel Cubby Digitizer Replacement: step 9, image 1 of 2 Sprout Channel Cubby Digitizer Replacement: step 9, image 2 of 2
      • To take out the digitizer, remove the connector ribbon from the plastic and then slowly apply pressure to the corner and edges of the digitizer.
      Ask FixBot
5 other people completed this guide.
Author
with
David Meyers
244 Reputation
1 Guide authored
USF Tampa, Team 14-101, Meier Fall 2015 Member of USF Tampa, Team 14-101, Meier Fall 2015
USFT-MEIER-F15S14G101
4 Members
72 Guides authored
4 Guide Comments
Ok I opened up the back and I accidentally pressed a little on the battery and now my screen is all white no picture. What did I do is there a way to fix the picture?
deysi gallegos - Reply Share
Most likely the LCD is broken and needs to be replaced.
Stephen Martinez - Reply Share
You don't need to remove the mother board or the battery from the LCD to replace the digitizer. Once you remove the screws from the motherboard you can lift it up to access the screw for the front bezel and access the bezel clips underneath. Taking the battery off the LCD will most likely damage the LCD, so don't even mess with it. After you have the front bezel removed, flip the entire assembly over and you can replace the digitizer. Make sure you remove all the black foam and adhesive from the case after the digitizer is removed. This makes assembly easier and prevents damage to the new digitizer.
I replaced my digitizer screen and it is still not working, what is the screen under the first screen called and it is still showing a dysfunctional screen
pam - Reply Share
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 105
All Time: 4,578
