Up to 20% off select tools
Sprout Channel Cubby Camera Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
80
All Time:
888
Comments: 3
3 comments on steps.
Completed: 0
Favorites: 0
Time Required: 4 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
This guide will require the use of a Phillips head screwdriver. The ribbon connector is usually the reason the device will need this replacement.
    1. Sprout Channel Cubby Camera Replacement, Dissasemble the device: step 1, image 1 of 2 Sprout Channel Cubby Camera Replacement, Dissasemble the device: step 1, image 2 of 2
      • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
      • It is easiest to start on the corners.
      Ask FixBot
    1. Sprout Channel Cubby Camera Replacement, Remove the screw: step 2, image 1 of 1
      • Remove the single screw attaching the camera to the device.
      Ask FixBot
    2. Sprout Channel Cubby Camera Replacement, Remove the camera: step 3, image 1 of 1
      Ask FixBot
Author
with
jasen biggins
741 Reputation
5 Guides authored
USF Tampa, Team 14-101, Meier Fall 2015 Member of USF Tampa, Team 14-101, Meier Fall 2015
USFT-MEIER-F15S14G101
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 80
All Time: 888
