Up to 20% off select tools
Sprout Channel Cubby Battery Replacement
Views: 4.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
23
Past 30 Days:
100
All Time:
4,551
Comments: 10
3 comments on steps, 7 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
  • iFixit Opening Tool
    4.8
  • Spudger
    4.9
Introduction
Go to step 1 ↓
The battery is fairly easy to replace the only issue with taking it out is the adhesive holding it in. the best way to do this is to heat it up, recommended tool is the iopener and the mettle spudger.
    1. Sprout Channel Cubby Battery Replacement, Dissasemble the device: step 1, image 1 of 2 Sprout Channel Cubby Battery Replacement, Dissasemble the device: step 1, image 2 of 2
      • Use an opening tool to push in and release sixteen small plastic clips around the edge of the case. As the clips are released, gradually pry the case apart.
      • It is easiest to start on the corners.
      Ask FixBot
    1. Sprout Channel Cubby Battery Replacement, Battery: step 2, image 1 of 2 Sprout Channel Cubby Battery Replacement, Battery: step 2, image 2 of 2
      • Remove the black electrical tape over the ribbon connector.
      • Remove the ribbon connector over the battery.
      • Make sure to be careful of the ribbon connector while working on the device.
      Ask FixBot
    2. Sprout Channel Cubby Battery Replacement: step 3, image 1 of 1
      • Next you must heat up the battery to help weaken the adhesive connecting the battery to the device.
      Ask FixBot
    3. Sprout Channel Cubby Battery Replacement: step 4, image 1 of 1
      • Once this is done start to pry the battery away from the device carefully. It helps to start at the corners and move inward.
      Ask FixBot
    4. Sprout Channel Cubby Battery Replacement: step 5, image 1 of 2 Sprout Channel Cubby Battery Replacement: step 5, image 2 of 2
      • Once you remove the battery from the device it is still connected by three wires: red, black, and, white. It is important to remember the order they are in when reconnecting the new battery.
      Ask FixBot
3 other people completed this guide.
Author
with
jasen biggins
741 Reputation
5 Guides authored
USF Tampa, Team 14-101, Meier Fall 2015 Member of USF Tampa, Team 14-101, Meier Fall 2015
USFT-MEIER-F15S14G101
4 Members
72 Guides authored
7 Guide Comments
Ours is only 6 months old. It only works when it stays plugged in. Battery is bad?
Rachel - Reply Share
I had the same problem, only played while plugged in and would not charge.. I found that the battery wires while appearing tight one wire had broken inside the wire insulation at the solder pad on the main board. When I redid the connection it charges, and works well. 8/11/16
larrywb135 - Reply Share
My grand daughters won't come on, should I take it to an electronic store?. I don't want to try and pry it open, for fear I may make it worse, she loves her tablet, and it is very helpful for her with school, she's had it 2 years and I put it away for about 8 month, for going on line, without permission, I gave it back in Sept. Now its not charging or coming on. Thank you.Deborah
jacksondebo2010 - Reply Share
Where can I get a battery?
crzyinind - Reply Share
You can get one at Amazon, EBay and more.
Liu Woods - Reply Share
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 100
All Time: 4,551
