Sprint Sanyo RL-4920 Display Replacement
  1. Sprint Sanyo RL-4920 Display Replacement, Back of Phone: step 1, image 1 of 1
    • Flip the phone over so that the screen is facing down.
    Ask FixBot
  2. Sprint Sanyo RL-4920 Display Replacement, Remove Battery Pack: step 2, image 1 of 2 Sprint Sanyo RL-4920 Display Replacement, Remove Battery Pack: step 2, image 2 of 2
    • Push the gray lever up towards the top of the phone.
    • Pull up on the battery pack and completely separate it from the phone.
    Ask FixBot
  3. Sprint Sanyo RL-4920 Display Replacement, Screws: step 3, image 1 of 2 Sprint Sanyo RL-4920 Display Replacement, Screws: step 3, image 2 of 2
    • Locate the five screws around the back casing.
    • Use a three-prong screw bit to remove all five screws.
    Ask FixBot
  4. Sprint Sanyo RL-4920 Display Replacement, Separate Cases: step 4, image 1 of 1
    • Use the plastic opening tool and slide it around the phone to pull apart the front and back casing.
    Ask FixBot
  5. Sprint Sanyo RL-4920 Display Replacement, Separate Cases: step 5, image 1 of 1
    • Separate the two cases.
    Ask FixBot
  6. Sprint Sanyo RL-4920 Display Replacement, The Front Case: step 6, image 1 of 1
    • Use the plastic opening tool to remove the motherboard from the front case.
    Ask FixBot
  7. Sprint Sanyo RL-4920 Display Replacement, Display: step 7, image 1 of 2 Sprint Sanyo RL-4920 Display Replacement, Display: step 7, image 2 of 2
    • Locate the 4 white clips of the dispaly.
    Ask FixBot
  8. Sprint Sanyo RL-4920 Display Replacement: step 8, image 1 of 2 Sprint Sanyo RL-4920 Display Replacement: step 8, image 2 of 2
    • Using the plastic opening tool, pull the white clips of the display away from the printed circuit board to unclip display.
    Ask FixBot
  9. Sprint Sanyo RL-4920 Display Replacement: step 9, image 1 of 2 Sprint Sanyo RL-4920 Display Replacement: step 9, image 2 of 2
    • Grasp the display on both sides and carefully pull the display off of the printed circuit board.
    Ask FixBot
  10. Sprint Sanyo RL-4920 Display Replacement: step 10, image 1 of 2 Sprint Sanyo RL-4920 Display Replacement: step 10, image 2 of 2
    • Using the plastic opening tool, carefully remove the yellow film covering the display connector.
    • Do not damage the yellow film. Ensure that it stays in one piece and does not tear.
    Ask FixBot
Patrick Olmstead
240 Reputation
2 Guides authored
Clemson, Team 13-5, Benson Fall 2013 Member of Clemson, Team 13-5, Benson Fall 2013
CLEM-BENSON-F13S13G5
3 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 21
All Time: 463
