Up to 20% off select tools
Sprinkler Head Replacement
Views: 2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
32
Past 30 Days:
139
All Time:
1,986
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Many people have a sprinkler system and sprinkler heads tend to break occasionally. This guide will help people accomplish the task of replacing broken sprinkler heads themselves. Broken sprinkler heads can be diagnosed by the observance of poor water flow, incorrect water distribution or water shooting out like a geyser. By following the steps laid out in this guide, this project will reduce water usage and brown spots by assuring broken sprinkler heads are replaced properly.
    1. Sprinkler Head Replacement, Sprinkler Head: step 1, image 1 of 1
      • Turn off the water supply to the sprinklers.
      • This process will vary depending on your sprinkler controller.
      Ask FixBot
    2. Sprinkler Head Replacement: step 2, image 1 of 1
      • Find where the water supply feeds the sprinkler system and close the valve in the event of emergency or unforeseen circumstances.
      Ask FixBot
    3. Sprinkler Head Replacement: step 3, image 1 of 1
      • Dig a hole down to the base of the sprinkler head.
      • Be careful to avoid puncturing the sprinkler line.
      Ask FixBot
    4. Sprinkler Head Replacement: step 4, image 1 of 1
      • Using your hand or a gardening trowel, finish digging so that the sprinkler head is fully visible and is clear of dirt and debris.
      Ask FixBot
    5. Sprinkler Head Replacement: step 5, image 1 of 2 Sprinkler Head Replacement: step 5, image 2 of 2
      • Unscrew the sprinkler head from the line it is attached to.
      • If is loose enough you may not need pliers.
      Ask FixBot
    6. Sprinkler Head Replacement: step 6, image 1 of 2 Sprinkler Head Replacement: step 6, image 2 of 2
      • Coat the threads of the water line with teflon tape to avoid leaking.
      Ask FixBot
    7. Sprinkler Head Replacement: step 7, image 1 of 2 Sprinkler Head Replacement: step 7, image 2 of 2
      • Using your hand, screw the new sprinkler head on over the teflon tape.
      • Once the sprinkler head is hand tight, use pliers to tighten it by another half turn.
      Ask FixBot
    8. Sprinkler Head Replacement: step 8, image 1 of 1
      • Fill the hole in and pack it down to avoid unwanted movement of the new sprinkler head.
      Ask FixBot
    9. Sprinkler Head Replacement: step 9, image 1 of 1
      • Turn the sprinkler system on.
      Ask FixBot
    10. Sprinkler Head Replacement: step 10, image 1 of 1
      • Twist the top of the sprinkler until it is aimed where you want it.
      Ask FixBot
    11. Sprinkler Head Replacement: step 11, image 1 of 1
      • Use a flat head screwdriver to adjust the flow of water if needed.
      • Turning right decreases the water flow. Turning left increases the water flow.
      Ask FixBot
Enjoy your green lawn and water savings.
Author
with
Adam Sylvia
251 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 139
All Time: 1,986
