Spiral Bound Notebook Cover Replacement
    1. Spiral Bound Notebook Cover Replacement, Cover: step 1, image 1 of 2 Spiral Bound Notebook Cover Replacement, Cover: step 1, image 2 of 2
      • Use a binder clip on either end to hold the paper block together, excluding the damaged cover.
      Ask FixBot
    2. Spiral Bound Notebook Cover Replacement: step 2, image 1 of 3 Spiral Bound Notebook Cover Replacement: step 2, image 2 of 3 Spiral Bound Notebook Cover Replacement: step 2, image 3 of 3
      • Uncoil the free end of the spiral.
      Ask FixBot
    3. Spiral Bound Notebook Cover Replacement: step 3, image 1 of 3 Spiral Bound Notebook Cover Replacement: step 3, image 2 of 3 Spiral Bound Notebook Cover Replacement: step 3, image 3 of 3
      • Push the spiral end back through the binding hole and pull it out.
      Ask FixBot
    4. Spiral Bound Notebook Cover Replacement: step 4, image 1 of 1
      • Repeat previous step until spiral is removed.
      Ask FixBot
    5. Spiral Bound Notebook Cover Replacement: step 5, image 1 of 1
      • Take the damaged cover and place it over the cardstock, aligning them at the edges.
      Ask FixBot
    6. Spiral Bound Notebook Cover Replacement: step 6, image 1 of 3 Spiral Bound Notebook Cover Replacement: step 6, image 2 of 3 Spiral Bound Notebook Cover Replacement: step 6, image 3 of 3
      • Trace the cover edges.
      Ask FixBot
    7. Spiral Bound Notebook Cover Replacement: step 7, image 1 of 2 Spiral Bound Notebook Cover Replacement: step 7, image 2 of 2
      • Trace the cover binding holes.
      Ask FixBot
    8. Spiral Bound Notebook Cover Replacement: step 8, image 1 of 3 Spiral Bound Notebook Cover Replacement: step 8, image 2 of 3 Spiral Bound Notebook Cover Replacement: step 8, image 3 of 3
      • Using a hole punch, punch out the traced holes on the cardstock sheet.
      Ask FixBot
    9. Spiral Bound Notebook Cover Replacement: step 9, image 1 of 3 Spiral Bound Notebook Cover Replacement: step 9, image 2 of 3 Spiral Bound Notebook Cover Replacement: step 9, image 3 of 3
      • Cut off the traced edges on the cardstock sheet.
      Ask FixBot
    10. Spiral Bound Notebook Cover Replacement: step 10, image 1 of 2 Spiral Bound Notebook Cover Replacement: step 10, image 2 of 2
      • Without removing the binding clip, open it and slide the cardstock onto the paper block while making sure their holes aligned.
      Ask FixBot
    11. Spiral Bound Notebook Cover Replacement: step 11, image 1 of 3 Spiral Bound Notebook Cover Replacement: step 11, image 2 of 3 Spiral Bound Notebook Cover Replacement: step 11, image 3 of 3
      • Perform Steps 1 through 4 in reverse to complete the replacement.
      Ask FixBot
To reassemble your device, follow instructions 1 - 4 in reverse order.
Abel Mbaziira
220 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 29
Past 30 Days: 143
All Time: 6,016
