Up to 20% off select tools
Spin Master Boxer Remote Trigger Buttons Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
81
All Time:
1,566
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If you need to replace either one of the two top buttons, or trigger buttons, on the remote for the Spin Master Boxer Bot, follow this guide. If you only wanted access to replacing remote joysticks, this guide will work as well. To follow this replacement guide you will need Size 00 Philips Screwdriver, as well as a flat metal opening tool, the Jimmy.
    1. Spin Master Boxer Remote Trigger Buttons Replacement, Remote Trigger Buttons: step 1, image 1 of 1
      • Lay the remote flat on your work space, with joysticks facing you.
      Ask FixBot
    2. Spin Master Boxer Remote Trigger Buttons Replacement: step 2, image 1 of 1
      • Remove both joysticks by gripping under circular knob and gently pulling towards you.
      • The joysticks should detach without much effort.
      Ask FixBot
    3. Spin Master Boxer Remote Trigger Buttons Replacement: step 3, image 1 of 1
      • Use the Phillips #00 Screwdriver to remove 4mm screw on the center battery panel.
      • Remove the batteries from the remote and set it to side.
      • Use the same screwdriver to remove all four 4mm screws on back panel.
      Ask FixBot
    4. Spin Master Boxer Remote Trigger Buttons Replacement: step 4, image 1 of 2 Spin Master Boxer Remote Trigger Buttons Replacement: step 4, image 2 of 2
      • Insert the Jimmy in between the top panel and the bottom panel.
      • Gently use the Jimmy to separate both plastic panels from each other.
      • Pull the panels apart and set bottom piece on workbench.
      Ask FixBot
    5. Spin Master Boxer Remote Trigger Buttons Replacement: step 5, image 1 of 2 Spin Master Boxer Remote Trigger Buttons Replacement: step 5, image 2 of 2
      • Pinch the trigger between index finger and thumb, and lift up, away from circuit board.
      • Inspect the square button attached to circuit board to ensure functionality. If there is an issue with connection, a new circuit boards may be required.
      Ask FixBot
Author
with
Lauren Roide
769 Reputation
5 Guides authored
Cal Poly, Team S1-G1, Maness Spring 2019 Member of Cal Poly, Team S1-G1, Maness Spring 2019
CPSU-MANESS-S19S1G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 81
All Time: 1,566
