Up to 20% off select tools
Speed up your windows PC
View statistics:
Past 24 Hours:
3
Past 7 Days:
27
Past 30 Days:
138
All Time:
527
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
    1. Speed up your windows PC, Simple Disk Clear-up: step 1, image 1 of 2 Speed up your windows PC, Simple Disk Clear-up: step 1, image 2 of 2
      • Press the windows key and search for "Disk Cleanup"
      • Now select all boxes, this will remove files that aren't needed. NOTE It does include the recycle bin, make sure you are ok with permanently deleting all of the recycle bins contents
      • Once your ready click OK and it will start deleting all the files that are not needed! This will clear up your disk and improve speed!
      Ask FixBot
    2. Speed up your windows PC, Uninstall Unused Apps: step 2, image 1 of 1
      • First click windows + R then type in "appwiz.cpl"
      • Find apps you do not need installed and click uninstall at the top panel.
      Ask FixBot
    3. Speed up your windows PC, Turning off animations: step 3, image 1 of 1
      • Press the windows key and search for "Adjust the appearance and performance of windows"
      • Once opened, select "Adjust for best performance" Then click "Apply" and "Ok"
      Ask FixBot
    4. Speed up your windows PC, Create a better power plan: step 4, image 1 of 1
      • Press the Windows Key, type cmd, right-click Command Prompt, and select "Run as administrator"
      • Paste the following command and press Enter: powercfg -duplicatescheme e9a42b02-d5df-448d-aa00-03f14749eb61
      • Press the Windows Key, type control panel and navigate: Hardware and Sound > Power Options and select Ultimate Performance
      Ask FixBot
Now you will have improved your PC's speed!
Author
with
Snazzy
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 138
All Time: 527
