Up to 20% off select tools
Speaker Unit Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
100
All Time:
1,770
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
This guide will walk you through the process of replacing dead speakers on the iHome iP37.
    1. Speaker Unit Replacement, Exterior Housing: step 1, image 1 of 3 Speaker Unit Replacement, Exterior Housing: step 1, image 2 of 3 Speaker Unit Replacement, Exterior Housing: step 1, image 3 of 3
      Tool used on this step:
      iOpener
      $24.95
      Buy
      • Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
      • Note: This step is the most difficult due to the way it is attached. The glue holding the exterior housing to the internals does not break easily. You may want to use iFixit's iOpener to soften the glue.
      • Note: The process is the same for both the upper half and the lower half. To identify the halves, look for these details: the upper half has a metal grid, and the lower half has buttons. If you are replacing any other components, pry off the lower half.
      Ask FixBot
    1. Speaker Unit Replacement, Speaker Unit: step 2, image 1 of 1
      • Remove these eight 9 mm screws using a Phillips #2 driver.
      Ask FixBot
    2. Speaker Unit Replacement: step 3, image 1 of 1
      • Carefully lift the cover off. It may be a little sticky from glue.
      Ask FixBot
    3. Speaker Unit Replacement: step 4, image 1 of 1
      • Remove the four 6mm screws that hold the broken speaker in place. This step requires a Phillips #1 driver. If you are replacing both speakers, remove all 8 screws.
      Ask FixBot
    4. Speaker Unit Replacement: step 5, image 1 of 1
      • Caution: the speaker is fitted quite snug. it may take a bit of effort to remove. However, be careful not to pull too hard as you may accidentally pull on the wires once the speaker unit is free.
      • Hold the speaker by its cylindrical frame and cautiously lift it away from the rest of the device.
      Ask FixBot
    5. Speaker Unit Replacement: step 6, image 1 of 1
      • De-solder the existing soldered connections and remove the speaker from the rest of the device.
      • Insert and solder in a working speaker of the same model. Make sure the points where the wire ends connected are consistent with the old speakers.
      • Note: If you notice that a wire is disconnected, this may be the cause of your problems. Re-solder the connection to fix it.
      • You can refer to iFixit's guide or this informative video for more information on soldering.
      Ask FixBot
Author
with
Jerrell
730 Reputation
7 Guides authored
Cal Poly, Team 11-50, Amido Spring 2014 Member of Cal Poly, Team 11-50, Amido Spring 2014
CPSU-AMIDO-S14S11G50
4 Members
96 Guides authored
1 Guide Comment
Good afternoom, my name is vladimir and i ‘m interested both speakers, where i could fi nd them to replace in my ihome? Could you help me?
Vladinir reyes - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 100
All Time: 1,770
