Up to 20% off select tools
Soundboks 4 Tweeter Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
87
All Time:
148
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Does your speaker sound like being underwater?
Probably the tweeter is failing. Here is an easy guide on how to replace it.
    1. Soundboks 4 Tweeter Replacement, Getting ready: step 1, image 1 of 2 Soundboks 4 Tweeter Replacement, Getting ready: step 1, image 2 of 2
      • Turn off your speaker by disconnecting the battery
      Ask FixBot
    2. Soundboks 4 Tweeter Replacement, Remove the grille: step 2, image 1 of 3 Soundboks 4 Tweeter Replacement, Remove the grille: step 2, image 2 of 3 Soundboks 4 Tweeter Replacement, Remove the grille: step 2, image 3 of 3
      • Put the speaker flat down on its back
      • Use the hook in each corner and pull lightly upwards
      • Don't pull up the grille more than a few cm before all corners are loose
      • The grille is now removed by hand
      Ask FixBot
    3. Soundboks 4 Tweeter Replacement, Unscrew and remove the tweeter: step 3, image 1 of 3 Soundboks 4 Tweeter Replacement, Unscrew and remove the tweeter: step 3, image 2 of 3 Soundboks 4 Tweeter Replacement, Unscrew and remove the tweeter: step 3, image 3 of 3
      • Unscrew the 5 screws with a screwdriver or a drill (3mm hex bit) and gently remove the tweeter
      • Careful removing the tweeter as there are 2 cables connected to it
      • When screwing the new tweeter, tight it enough but without overdoing it
      Ask FixBot
    4. Soundboks 4 Tweeter Replacement, Unplug the 2 cables: step 4, image 1 of 2 Soundboks 4 Tweeter Replacement, Unplug the 2 cables: step 4, image 2 of 2
      • Gently press the tab on the cable connector and pull to remove the cables from the tweeter
      • The terminals has different sizes, to avoid wrong connections
      Ask FixBot
    5. Soundboks 4 Tweeter Replacement, Attach the cables to the new tweeter: step 5, image 1 of 2 Soundboks 4 Tweeter Replacement, Attach the cables to the new tweeter: step 5, image 2 of 2
      • Attach the cables to the new Tweeter, make sure to click them in and use the correct one for each clip size
      • You can follow the previous steps to put it back and get it running!
      Ask FixBot
SOUNDBOKS Tech Crew
42 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 87
All Time: 148
