Up to 20% off select tools
Soundboks 4 DC Cable Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
27
Past 30 Days:
99
All Time:
197
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
If something got stuck in your DC battery input, you may need a new wire harness.
This guide helps you do a DC plug replacement for the Soundboks 4.
Have fun!
    1. Soundboks 4 DC Cable Replacement, Getting Ready: step 1, image 1 of 1
      • Turn off your speaker by removing the battery
      Ask FixBot
    2. Soundboks 4 DC Cable Replacement, Remove the UI Panel: step 2, image 1 of 3 Soundboks 4 DC Cable Replacement, Remove the UI Panel: step 2, image 2 of 3 Soundboks 4 DC Cable Replacement, Remove the UI Panel: step 2, image 3 of 3
      • Unscrew the UI panel with the 3mm Hex bit - 6 screws in total
      • Pull the panel out at an angle. Pulling it straight can damage the PCBA!
      Ask FixBot
    3. Soundboks 4 DC Cable Replacement, Unplug and cut the DC Wire: step 3, image 1 of 3 Soundboks 4 DC Cable Replacement, Unplug and cut the DC Wire: step 3, image 2 of 3 Soundboks 4 DC Cable Replacement, Unplug and cut the DC Wire: step 3, image 3 of 3
      • Unplug the connector by pressing the top
      • Cut the cable
      Ask FixBot
    4. Soundboks 4 DC Cable Replacement, Untie the wire harness: step 4, image 1 of 1
      • Untie the wire harness
      • Make sure to tie the wire harness once re-assembling it
      Ask FixBot
    5. Soundboks 4 DC Cable Replacement, Remove the DC Connector: step 5, image 1 of 3 Soundboks 4 DC Cable Replacement, Remove the DC Connector: step 5, image 2 of 3 Soundboks 4 DC Cable Replacement, Remove the DC Connector: step 5, image 3 of 3
      • Unscrew the DC plug connector with the 2mm Hex bit - 2 screws
      • Pull the connector and wire all the way out.
      Ask FixBot
    6. Soundboks 4 DC Cable Replacement, Insert and fasten the new wire: step 6, image 1 of 3 Soundboks 4 DC Cable Replacement, Insert and fasten the new wire: step 6, image 2 of 3 Soundboks 4 DC Cable Replacement, Insert and fasten the new wire: step 6, image 3 of 3
      • You must insert the wire in the speaker - before assembling the wire
      • Insert and fasten the new DC Plug with the 2mm Hex screws
      • Do not over-tighten the screws
      Ask FixBot
    7. Soundboks 4 DC Cable Replacement, Assemble the ferrite: step 7, image 1 of 3 Soundboks 4 DC Cable Replacement, Assemble the ferrite: step 7, image 2 of 3 Soundboks 4 DC Cable Replacement, Assemble the ferrite: step 7, image 3 of 3
      • Pass the wire through the provided ferrite
      • Loop the wire through the ferrite
      Ask FixBot
    8. Soundboks 4 DC Cable Replacement, Foam assembly: step 8, image 1 of 2 Soundboks 4 DC Cable Replacement, Foam assembly: step 8, image 2 of 2
      • Wrap the foam around the ferrite
      Ask FixBot
    9. Soundboks 4 DC Cable Replacement, Connector assembly: step 9, image 1 of 3 Soundboks 4 DC Cable Replacement, Connector assembly: step 9, image 2 of 3 Soundboks 4 DC Cable Replacement, Connector assembly: step 9, image 3 of 3
      • Make sure the red cable is placed as indicated in the picture
      • Plug the wire as indicated, make sure the molex crimps face towards the molex clip
      • Push the cables into the connector until you hear a "click"
      • It only fits in one direction - make sure you hear the click and check it!
      • Check: Pull the wires (medium strenght), to check that they don't come out.
      Ask FixBot
SOUNDBOKS Tech Crew
42 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 99
All Time: 197
