Up to 20% off select tools
SoundBot SB571 Battery Replacement
Views: 10K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
173
All Time:
10,023
Comments: 10
1 comment on steps, 9 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Replacing the battery requires opening up the speaker and unscrewing the bottom and upper part of the speaker. You will need a Phillips screw driver, blue plastic opening tool and a new battery.
    1. SoundBot SB571 Battery Replacement, Battery: step 1, image 1 of 1
      • Before disassembling the speaker, make sure it is powered off.
      • Place the speaker on a flat surface.
      • Take your blue plastic opening tool and remove the outside cover.
      Ask FixBot
    2. SoundBot SB571 Battery Replacement: step 2, image 1 of 1
      • Reorient the speaker so the black panel is facing up.
      • Remove the 4, 0.9 cm screws from the back panel using a Phillips PH1 screwdriver.
      • Now remove the plate.
      Ask FixBot
    3. SoundBot SB571 Battery Replacement: step 3, image 1 of 1
      • Reorient the speaker so the bottom is facing up.
      • Remove the 4, 0.9cm screws from the bottom using a Phillips PH0 screw driver.
      • Now open the plate.
      Ask FixBot
    4. SoundBot SB571 Battery Replacement: step 4, image 1 of 2 SoundBot SB571 Battery Replacement: step 4, image 2 of 2
      • With the bottom plate removed now use the blue plastic opening tool to lift up the circuit board from the device.
      Ask FixBot
    5. SoundBot SB571 Battery Replacement: step 5, image 1 of 2 SoundBot SB571 Battery Replacement: step 5, image 2 of 2
      • Disconnect the battery wires from the circuit board.
      Ask FixBot
    6. SoundBot SB571 Battery Replacement: step 6, image 1 of 3 SoundBot SB571 Battery Replacement: step 6, image 2 of 3 SoundBot SB571 Battery Replacement: step 6, image 3 of 3
      • Reorient the speaker so the back side is facing up.
      • Now that the battery wires have been disconnected, use a blue plastic tool to release the battery from the adhesive strip.
      • Loop the battery wires through the opening in the back plate.
      • The battery and it's connective wires have been completely removed from the speaker.
      Ask FixBot
12 other people completed this guide.
Author
with
Yana
672 Reputation
2 Guides authored
USF Tampa, Team 2-50, Cagle Spring 2016 Member of USF Tampa, Team 2-50, Cagle Spring 2016
USFT-CAGLE-S16S2G50
4 Members
24 Guides authored
9 Guide Comments
Please provide the source to buy the replacement battery
Madhu Mohan Bhukya - Reply Share
Sir ,m n jully m flipcart se soundbot buy tha jisme kuch dikat aa rhi h bettery ki bajah se
Raj Saini - Reply Share
They don't sell batteries!!
international.loop - Reply Share
It says above that battery not for sale.
A simple online search and you will find the battery.
Mark Friend - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 173
All Time: 10,023
