Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓These explanations are intended to guide you through the steps for disassembling the Sony Alpha 7 II in order to fix a recurring problem with this model: the instability of buttons that appear randomly. This problem stems from the method used by Sony to connect all the upper components: a large flex cable folded haphazardly.
It's a defect that may be covered by insurances. If you have this option, use it! It's far less tedious than waging war against the flex cable octopus.
Any person brave enough for this battle should proceed with patience, as many elements are fragile. I also recommend organizing everything with a magnetic mat, since this model contains several different screws.
The name of the target piece is RL-1048-12. It's compatible with nearly everything in the A7 series. Select your replacement **with cable connectors**! There is a cheaper option without them, but that's closer to self-imposed torture than repair.
PS : If the cable I purchased holds up long term, I will include the purchase link (Aliexpress). If it doesn't, I will do some research until I find a reliable replacement to recommend.
Please note:
I have not yet worked out all the elements and details that matter for a repair job in the best conditions possible. I will continue working on it until I reach a quality that suits the community.
Tools
Unscrew the four 4 mm Phillips #00 screws.
Unscrew the 2.5 mm Phillips #00 screw.
Unscrew the three 4 mm Phillips screws.
Unscrew the 5 mm Phillips screw.
Slide up the viewfinder.
Unscrew the four 4 mm Phillips screws.
Unscrew the 4 mm Phillips screw, but leave it in the settings knob.
Unscrew the two 2 mm Phillips #00 screws on the back.
Unscrew the two 1.5 mm Phillips #00 screws at the bottom.
Slide up the cable guide in order to release it.
Unfold the hinge, flip the screen over.
Loosen the flex cable.
Slide up the screen cover.
Then "open" it along the hinge.
Open the lock of the flex cable.
Remove it, and gently place the screen assembly and hinge aside.
Unscrew the three 2.5 mm Phillips #00 screws.
Remove the back cover assembly.
Unscrew the 4 mm Phillips screw.
Disconnect the scroll wheel cable.
Lift the ribbon cable to gain access to a 5 mm Phillips #00 screw and unscrew it.
Open the left latch to gain access to a 5 mm Phillips #00 screw, then unscrew it.
Gently lift up the shield to remove it.
Disconnect the flex cable from the SD drive by gently lifting the white plastic lock. Remove the assembly.
Disconnect the screen flex cable by gently lifting the white plastic lock. Remove the cable.
Unscrew the two 2 mm Phillips screws.
Disconnect the twelve flex cables. Be careful with the locking mechanisms, they are fragile!
Slide these flex cables out
Lock on the side of the motherboard
Lock on the side of the cable
Remove the antenna.
Remove the motherboard by first lifting it slightly up.
Insert the screwdriver through the hole.
Gently pull the flex cable to release the front grip.
Unscrew the two 4 mm Phillips screws.
Unscrew the 2 mm Phillips screw.
Disconnect the flex cable.
Disconnect the antenna.
Gently remove the viewfinder. It's not fixed by screws, but just by a thermal pad inside the recess.
After lifting the upper cover, disconnect the flex cable from the body of the device by lifting it from the back, then pushing it.
Disconnect the blue flex by gently pulling on it
Unscrew the two 3 mm Phillips screws.
Pull the cover with the knob towards the back in order to release them.
The cable is not glued to the knob, you can just pull it up gently.
To reassemble your device, follow the instructions in reverse order.
Here is the link for the replacement item:
9 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
11 Guide Comments
Hi! Thanks so much for this information. I’m about to give it a go and wondered how the repair is holding up? Would you post the aliexpress link?
Most of the ones I’ve found are called “top cover shutter power switch flex cable” but the one poster at the top is a mounted C board?
Thanks!
Hi! Sorry about this late response. The repair is holding as well as new, I'm glad!
I posted a link, but I hope you did it in the meantime? If so, how did it go?
i found multiple in aliexpress, here's the one i got
https://es.aliexpress.com/item/100500751...
BE carefull, ensure you put all screws with right dimensions, and most importantly, be carefull of the orientation of the "MODE SELECTOR" i closed mine and now i have 3 positions offset.
At least it works now
Thanks for the guide, managed to replace mine and it's now all working great finally.
Used the following from AliExpress: https://www.aliexpress.com/item/10050053... (the second option which says "Bundle: With All Parts")
The only main issue I have with the guide is the instructions around the LCD removal and reassembly, as it took a few tries to get it right.
