Up to 20% off select tools
Sony a7 Rear Disassembly Replacement
Views: 10K
View statistics:
Past 24 Hours:
3
Past 7 Days:
26
Past 30 Days:
151
All Time:
10,250
Comments: 3
3 comments on steps.
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This is a pre-requisite list of steps that will act as a placeholder for all other applicable guides pertaining to the Sony a7.
    1. Sony a7 Rear Disassembly  Replacement, Rear Disassembly: step 1, image 1 of 1
      • Remove the eyepiece cover by removing the four M1.5x4mm screws with a PH00 Phillips screwdriver.
      • Remove the M1.5x4mm screw that retains the adjustment wheel with a PH00 Phillips screwdriver.
      Ask FixBot
    2. Sony a7 Rear Disassembly  Replacement: step 2, image 1 of 3 Sony a7 Rear Disassembly  Replacement: step 2, image 2 of 3 Sony a7 Rear Disassembly  Replacement: step 2, image 3 of 3
      • Remove the six M1.5x4mm screws with a PH00 Phillips screwdriver.
      Ask FixBot
    3. Sony a7 Rear Disassembly  Replacement: step 3, image 1 of 1
      • Remove one M1.5x4mm screw with a PH00 Phillips screwdriver.
      Ask FixBot
    4. Sony a7 Rear Disassembly  Replacement: step 4, image 1 of 2 Sony a7 Rear Disassembly  Replacement: step 4, image 2 of 2
      • Remove the four M 1.5x2mm screws.
      Ask FixBot
    5. Sony a7 Rear Disassembly  Replacement: step 5, image 1 of 3 Sony a7 Rear Disassembly  Replacement: step 5, image 2 of 3 Sony a7 Rear Disassembly  Replacement: step 5, image 3 of 3
      • Once the screws have been removed, unsnap and lift the rear plastic cover off of the camera.
      Ask FixBot
    6. Sony a7 Rear Disassembly  Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Using the blunt tweezers, remove the blue ribbon cable.
      • For additional guidance and tips on how to properly attach and detach connector cables, please reference iFixit's guide to connector cables here.
      Ask FixBot
    7. Sony a7 Rear Disassembly  Replacement: step 7, image 1 of 2 Sony a7 Rear Disassembly  Replacement: step 7, image 2 of 2
      • Place the tweezers on the side of the circuit board and lift it from underneath so as to free it from the three retaining tabs.
      Ask FixBot
    8. Sony a7 Rear Disassembly  Replacement: step 8, image 1 of 3 Sony a7 Rear Disassembly  Replacement: step 8, image 2 of 3 Sony a7 Rear Disassembly  Replacement: step 8, image 3 of 3
      • Remove four M1.5x4mm screws using a PH00 Phillips screwdriver.
      Ask FixBot
    9. Sony a7 Rear Disassembly  Replacement: step 9, image 1 of 1
      • Lift the metal plate and LCD screen away from the camera body.
      Ask FixBot
    10. Sony a7 Rear Disassembly  Replacement: step 10, image 1 of 1
      • Detach the amber ribbon cable from the motherboard.
      Ask FixBot
9 other people completed this guide.
Author
with
Jeffrey Coleman
1,402 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 151
All Time: 10,250
