Sony a7 Motherboard Replacement
    1. Sony a7 Motherboard Replacement, Battery: step 1, image 1 of 1
      • Flip the camera upside down, and observe where the battery door and switch are located on the camera.
      • This replacement guide is using a cardboard and tape placeholder to simulate the battery, battery door, and switch.
      Ask FixBot
    2. Sony a7 Motherboard Replacement: step 2, image 1 of 1
      • Slide the switch over to the right side to open the battery door.
      Ask FixBot
    3. Sony a7 Motherboard Replacement: step 3, image 1 of 1
      • Depress the blue lever to allow the battery to pop out slightly.
      Ask FixBot
    4. Sony a7 Motherboard Replacement: step 4, image 1 of 1
      • Remove the battery from the camera.
      • Make sure to hold onto the battery firmly when removing it from the camera, as it could slide out and fall.
      Ask FixBot
    1. Sony a7 Motherboard Replacement, Rear Disassembly: step 5, image 1 of 1
      • Remove the eyepiece cover by removing the four M1.5x4mm screws with a PH00 Phillips screwdriver.
      • Remove the M1.5x4mm screw that retains the adjustment wheel with a PH00 Phillips screwdriver.
      Ask FixBot
    2. Sony a7 Motherboard Replacement: step 6, image 1 of 3 Sony a7 Motherboard Replacement: step 6, image 2 of 3 Sony a7 Motherboard Replacement: step 6, image 3 of 3
      • Remove the six M1.5x4mm screws with a PH00 Phillips screwdriver.
      Ask FixBot
    3. Sony a7 Motherboard Replacement: step 7, image 1 of 1
      • Remove one M1.5x4mm screw with a PH00 Phillips screwdriver.
      Ask FixBot
    4. Sony a7 Motherboard Replacement: step 8, image 1 of 2 Sony a7 Motherboard Replacement: step 8, image 2 of 2
      • Remove the four M 1.5x2mm screws.
      Ask FixBot
    5. Sony a7 Motherboard Replacement: step 9, image 1 of 3 Sony a7 Motherboard Replacement: step 9, image 2 of 3 Sony a7 Motherboard Replacement: step 9, image 3 of 3
      • Once the screws have been removed, unsnap and lift the rear plastic cover off of the camera.
      Ask FixBot
    6. Sony a7 Motherboard Replacement: step 10, image 1 of 1
      Tool used on this step:
      Buy
      • Using the blunt tweezers, remove the blue ribbon cable.
      • For additional guidance and tips on how to properly attach and detach connector cables, please reference iFixit's guide to connector cables here.
      Ask FixBot
    7. Sony a7 Motherboard Replacement: step 11, image 1 of 2 Sony a7 Motherboard Replacement: step 11, image 2 of 2
      • Place the tweezers on the side of the circuit board and lift it from underneath so as to free it from the three retaining tabs.
      Ask FixBot
    8. Sony a7 Motherboard Replacement: step 12, image 1 of 3 Sony a7 Motherboard Replacement: step 12, image 2 of 3 Sony a7 Motherboard Replacement: step 12, image 3 of 3
      • Remove four M1.5x4mm screws using a PH00 Phillips screwdriver.
      Ask FixBot
    9. Sony a7 Motherboard Replacement: step 13, image 1 of 1
      • Lift the metal plate and LCD screen away from the camera body.
      Ask FixBot
    10. Sony a7 Motherboard Replacement: step 14, image 1 of 1
      • Detach the amber ribbon cable from the motherboard.
      Ask FixBot
    1. Sony a7 Motherboard Replacement, Motherboard: step 15, image 1 of 2 Sony a7 Motherboard Replacement, Motherboard: step 15, image 2 of 2
      • Peel off the small adhesive tape located on the top right side of the motherboard.
      Ask FixBot
    2. Sony a7 Motherboard Replacement: step 16, image 1 of 2 Sony a7 Motherboard Replacement: step 16, image 2 of 2
      • Remove the exposed ribbon cable by using the iFixit opening tools
      Ask FixBot
    3. Sony a7 Motherboard Replacement: step 17, image 1 of 1
      • Peel off the large black protective adhesive from the motherboard.
      Ask FixBot
    4. Sony a7 Motherboard Replacement: step 18, image 1 of 2 Sony a7 Motherboard Replacement: step 18, image 2 of 2
      • Remove the four visible ribbon cables by using the spudger.
      • Removing the ribbon cables will require lifting a lever located on the connecter in order to pull out the cable.
      Ask FixBot
    5. Sony a7 Motherboard Replacement: step 19, image 1 of 3 Sony a7 Motherboard Replacement: step 19, image 2 of 3 Sony a7 Motherboard Replacement: step 19, image 3 of 3
      • Remove the one U.FL plug by using the spudger.
      • Using the spudger, remove the four remaining ribbon cables.
      • These ribbon cables do not have the requirement to lift a lever on the connector as specified in previous steps.
      Ask FixBot
    6. Sony a7 Motherboard Replacement: step 20, image 1 of 1
      • Remove one M1.5x2mm screw with a PH00 Phillips screwdriver.
      • Remove one coarse threaded 5mm screw with a PH00 Phillips screwdriver.
      Ask FixBot
    7. Sony a7 Motherboard Replacement: step 21, image 1 of 3 Sony a7 Motherboard Replacement: step 21, image 2 of 3 Sony a7 Motherboard Replacement: step 21, image 3 of 3
      • Lift the motherboard from the camera body.
      • It helps to pick up the right side of the board first, and then work sequentially down the board. Be sure to gently ease the motherboard from its clips down the remainder of the side.
      • Exercise extreme caution when removing the motherboard as it can be fragile, and damage to it could mean the camera will become unrecoverable.
      Ask FixBot
    8. Sony a7 Motherboard Replacement: step 22, image 1 of 1
      • Remove the two visible ribbon cables by using the forceps.
      Ask FixBot
5 other people completed this guide.
1 Guide Comment
For SD card replacement:
Follow above guide to step 18. Remove the bottom right flex cable. There will be a hole under the cable to access a screw in the battery compartment, which holds on the grip. Remove the screw. Remove the one remaining screw in the corner of the battery compartment. The grip should now come loose. Remove the grip. Remove the two screws holding the SD card board on. Disconnect the small two wire cable from the top of the board. The board should now slide out. Disconnect the flex cable from the old board and connect to the new board for reinstall.
I did this for a Sony A7S and all is working well.
Sam Hudson - Reply Share
Past 24 Hours: 9
Past 7 Days: 31
Past 30 Days: 138
All Time: 11,749
