Up to 20% off select tools
Sony a7 AV Port Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
80
All Time:
3,108
Comments: 8
8 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 35 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
This replacement guide will address how to remove a damaged AV port from a Sony a7 model number ILCE-7 camera. The AV port is the centralized hub of all inputs and outputs for the camera. This step by step guide will provide the actions necessary to repair a faulty AV port.
If the camera is having difficulty connecting to an external device such as a computer or is unable to transfer photos and other files to an external storage platform then there is a possibility that the AV port is damaged. Before beginning this process, it may be helpful to reference this troubleshooting page, which could help with addressing issues before having to go through the tedious process of repairing the AV port. The special skill of soldering connectors will be required at certain points, a guide on how to do this can be found here.
Caution: It would be in the best interest of continuity to ensure that all files from the camera have been transferred and backed up. This replacement guide will require accessing the AV port and motherboard, which places the camera’s storage processes at risk of being damaged. If damage is incurred, there is a possibility that photos on the camera’s storage could be lost.
    1. Sony a7 AV Port Replacement, Rear Disassembly: step 1, image 1 of 1
      • Remove the eyepiece cover by removing the four M1.5x4mm screws with a PH00 Phillips screwdriver.
      • Remove the M1.5x4mm screw that retains the adjustment wheel with a PH00 Phillips screwdriver.
      Ask FixBot
    2. Sony a7 AV Port Replacement: step 2, image 1 of 3 Sony a7 AV Port Replacement: step 2, image 2 of 3 Sony a7 AV Port Replacement: step 2, image 3 of 3
      • Remove the six M1.5x4mm screws with a PH00 Phillips screwdriver.
      Ask FixBot
    3. Sony a7 AV Port Replacement: step 3, image 1 of 1
      • Remove one M1.5x4mm screw with a PH00 Phillips screwdriver.
      Ask FixBot
    4. Sony a7 AV Port Replacement: step 4, image 1 of 2 Sony a7 AV Port Replacement: step 4, image 2 of 2
      • Remove the four M 1.5x2mm screws.
      Ask FixBot
    5. Sony a7 AV Port Replacement: step 5, image 1 of 3 Sony a7 AV Port Replacement: step 5, image 2 of 3 Sony a7 AV Port Replacement: step 5, image 3 of 3
      • Once the screws have been removed, unsnap and lift the rear plastic cover off of the camera.
      Ask FixBot
    6. Sony a7 AV Port Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Using the blunt tweezers, remove the blue ribbon cable.
      • For additional guidance and tips on how to properly attach and detach connector cables, please reference iFixit's guide to connector cables here.
      Ask FixBot
    7. Sony a7 AV Port Replacement: step 7, image 1 of 2 Sony a7 AV Port Replacement: step 7, image 2 of 2
      • Place the tweezers on the side of the circuit board and lift it from underneath so as to free it from the three retaining tabs.
      Ask FixBot
    8. Sony a7 AV Port Replacement: step 8, image 1 of 3 Sony a7 AV Port Replacement: step 8, image 2 of 3 Sony a7 AV Port Replacement: step 8, image 3 of 3
      • Remove four M1.5x4mm screws using a PH00 Phillips screwdriver.
      Ask FixBot
    9. Sony a7 AV Port Replacement: step 9, image 1 of 1
      • Lift the metal plate and LCD screen away from the camera body.
      Ask FixBot
    10. Sony a7 AV Port Replacement: step 10, image 1 of 1
      • Detach the amber ribbon cable from the motherboard.
      Ask FixBot
    1. Sony a7 AV Port Replacement, Motherboard: step 11, image 1 of 2 Sony a7 AV Port Replacement, Motherboard: step 11, image 2 of 2
      • Peel off the small adhesive tape located on the top right side of the motherboard.
      Ask FixBot
    2. Sony a7 AV Port Replacement: step 12, image 1 of 2 Sony a7 AV Port Replacement: step 12, image 2 of 2
      • Remove the exposed ribbon cable by using the iFixit opening tools
      Ask FixBot
    3. Sony a7 AV Port Replacement: step 13, image 1 of 1
      • Peel off the large black protective adhesive from the motherboard.
      Ask FixBot
    4. Sony a7 AV Port Replacement: step 14, image 1 of 2 Sony a7 AV Port Replacement: step 14, image 2 of 2
      • Remove the four visible ribbon cables by using the spudger.
      • Removing the ribbon cables will require lifting a lever located on the connecter in order to pull out the cable.
      Ask FixBot
    5. Sony a7 AV Port Replacement: step 15, image 1 of 3 Sony a7 AV Port Replacement: step 15, image 2 of 3 Sony a7 AV Port Replacement: step 15, image 3 of 3
      • Remove the one U.FL plug by using the spudger.
      • Using the spudger, remove the four remaining ribbon cables.
      • These ribbon cables do not have the requirement to lift a lever on the connector as specified in previous steps.
      Ask FixBot
    6. Sony a7 AV Port Replacement: step 16, image 1 of 1
      • Remove one M1.5x2mm screw with a PH00 Phillips screwdriver.
      • Remove one coarse threaded 5mm screw with a PH00 Phillips screwdriver.
      Ask FixBot
    7. Sony a7 AV Port Replacement: step 17, image 1 of 3 Sony a7 AV Port Replacement: step 17, image 2 of 3 Sony a7 AV Port Replacement: step 17, image 3 of 3
      • Lift the motherboard from the camera body.
      • It helps to pick up the right side of the board first, and then work sequentially down the board. Be sure to gently ease the motherboard from its clips down the remainder of the side.
      • Exercise extreme caution when removing the motherboard as it can be fragile, and damage to it could mean the camera will become unrecoverable.
      Ask FixBot
    8. Sony a7 AV Port Replacement: step 18, image 1 of 1
      • Remove the two visible ribbon cables by using the forceps.
      Ask FixBot
    1. Sony a7 AV Port Replacement, AV Port: step 19, image 1 of 2 Sony a7 AV Port Replacement, AV Port: step 19, image 2 of 2
      • Take a soldering iron and place it onto a leg of the failed AV port.
      • Use a small flat head screwdriver to pry up each leg while the solder is molten.
      • The soldering iron and solder will be hot, exercise extreme caution when handling.
      • Always wear eye protection when soldering connections, solder can splatter and cause burns.
      • Do not inhale any smoke or fumes that may be given off during the soldering process, as they can be toxic.
      • For help and tips on how to effectively solder like a professional, please reference the iFixit guide on soldering here.
      Ask FixBot
    2. Sony a7 AV Port Replacement: step 20, image 1 of 1
      • Repeat the actions in the previous step to the remaining three legs of the faulty AV port until the connector is able to be moved, and is free.
      • All of the tips and cautions about the soldering process still apply in this step, continue to exercise extreme due diligence and caution.
      Ask FixBot
2 other people completed this guide.
Author
with
Jeffrey Coleman
1,402 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 80
All Time: 3,108
