Sony Xplod CDX-MP30 LCD Replacement
    1. Sony Xplod CDX-MP30 LCD Replacement, Front Panel: step 1, image 1 of 3 Sony Xplod CDX-MP30 LCD Replacement, Front Panel: step 1, image 2 of 3 Sony Xplod CDX-MP30 LCD Replacement, Front Panel: step 1, image 3 of 3
      • Press down the release button on the bottom left corner of the face plate.
      • Then remove the face plate carefully.
      Ask FixBot
    1. Sony Xplod CDX-MP30 LCD Replacement, LCD: step 2, image 1 of 1
      • Unscrew the four (length - 11.11mm) phillips-head screws on the front screen.
      Ask FixBot
    2. Sony Xplod CDX-MP30 LCD Replacement: step 3, image 1 of 3 Sony Xplod CDX-MP30 LCD Replacement: step 3, image 2 of 3 Sony Xplod CDX-MP30 LCD Replacement: step 3, image 3 of 3
      • Use two fingers to create a small gap on the top of the faceplate, as indicated in the picture.
      Ask FixBot
    3. Sony Xplod CDX-MP30 LCD Replacement: step 4, image 1 of 3 Sony Xplod CDX-MP30 LCD Replacement: step 4, image 2 of 3 Sony Xplod CDX-MP30 LCD Replacement: step 4, image 3 of 3
      Tool used on this step:
      Heavy-Duty Spudger
      Buy
      • Insert the flat end of the Heavy-duty Spudger into the opening you created.
      • Slide it to the right carefully, until you feel the screen pop off.
      • Make sure you keep the face of the screen pointed down as you carefully lift off the freed black portion of the screen - as shown in the picture.
      Ask FixBot
    4. Sony Xplod CDX-MP30 LCD Replacement: step 5, image 1 of 2 Sony Xplod CDX-MP30 LCD Replacement: step 5, image 2 of 2
      • Gently grab the Front Motherboard - as indicated in the picture - and lift it from the rest of the screen.
      Ask FixBot
    5. Sony Xplod CDX-MP30 LCD Replacement: step 6, image 1 of 1
      Ask FixBot
Kyle
132 Reputation
2 Guides authored
Cal Poly, Team 5-35, Amido Fall 2011 Member of Cal Poly, Team 5-35, Amido Fall 2011
CPSU-AMIDO-F11S5G35
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 24
All Time: 2,715
