Sony Xperia Z5 LCD Screen Replacement
Views: 103K
View statistics:
Past 24 Hours:
9
Past 7 Days:
38
Past 30 Days:
143
All Time:
103,020
Comments: 50
5 comments on steps, 45 guide comments.
Go to guide comments
Completed: 47
47 people have marked this guide "completed." Will you be next?
Favorites: 16
16 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 hours
Difficulty: Difficult
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓
This video shows how to replace and reassemble Sony Xperia Z5 LCD display.
Parts
Tools
Video Overview
    1. Sony Xperia Z5 LCD Screen Replacement, LCD Screen: step 1, image 1 of 2 Sony Xperia Z5 LCD Screen Replacement, LCD Screen: step 1, image 2 of 2
      • Remove SIM card tray.
      Ask FixBot
    2. Sony Xperia Z5 LCD Screen Replacement: step 2, image 1 of 2 Sony Xperia Z5 LCD Screen Replacement: step 2, image 2 of 2
      • Heat the back cover to soften the adhesive sticker.
      • Place the suction cup and insert metal opening tool to open a gap from top side.
      Ask FixBot
    3. Sony Xperia Z5 LCD Screen Replacement: step 3, image 1 of 3 Sony Xperia Z5 LCD Screen Replacement: step 3, image 2 of 3 Sony Xperia Z5 LCD Screen Replacement: step 3, image 3 of 3
      • Insert the guitar pick and slide it to cut the adhesive sticker underneath.
      • Remove back cover.
      Ask FixBot
    4. Sony Xperia Z5 LCD Screen Replacement: step 4, image 1 of 3 Sony Xperia Z5 LCD Screen Replacement: step 4, image 2 of 3 Sony Xperia Z5 LCD Screen Replacement: step 4, image 3 of 3
      • Release battery connector.
      • Pull off the adhesive tape underneath the battery.
      • Pry up battery.
      Ask FixBot
    5. Sony Xperia Z5 LCD Screen Replacement: step 5, image 1 of 3 Sony Xperia Z5 LCD Screen Replacement: step 5, image 2 of 3 Sony Xperia Z5 LCD Screen Replacement: step 5, image 3 of 3
      • Release rear camera connector, front camera connector, audio jack connector and main flex connector on the motherboard.
      • Twist off screws there.
      • Remove that rubber securing bracket.
      Ask FixBot
    6. Sony Xperia Z5 LCD Screen Replacement: step 6, image 1 of 3 Sony Xperia Z5 LCD Screen Replacement: step 6, image 2 of 3 Sony Xperia Z5 LCD Screen Replacement: step 6, image 3 of 3
      • Remove metal cover and twist off two screws.
      • Loosen the bottom side of main flex assembly.
      Ask FixBot
    7. Sony Xperia Z5 LCD Screen Replacement: step 7, image 1 of 3 Sony Xperia Z5 LCD Screen Replacement: step 7, image 2 of 3 Sony Xperia Z5 LCD Screen Replacement: step 7, image 3 of 3
      • Loosen side button contactors ( Attention: the fingerprint sensor is here, be careful to loosen it), then remove the whole main flex assembly.
      Ask FixBot
    8. Sony Xperia Z5 LCD Screen Replacement: step 8, image 1 of 3 Sony Xperia Z5 LCD Screen Replacement: step 8, image 2 of 3 Sony Xperia Z5 LCD Screen Replacement: step 8, image 3 of 3
      • Remove rear camera.
      • Remove that securing bracket, then remove front camera.
      Ask FixBot
    9. Sony Xperia Z5 LCD Screen Replacement: step 9, image 1 of 3 Sony Xperia Z5 LCD Screen Replacement: step 9, image 2 of 3 Sony Xperia Z5 LCD Screen Replacement: step 9, image 3 of 3
      • Release LCD screen flex connector, charging port connector, microphone connector here.
      • Remove motherboard.
      Ask FixBot
    10. Sony Xperia Z5 LCD Screen Replacement: step 10, image 1 of 2 Sony Xperia Z5 LCD Screen Replacement: step 10, image 2 of 2
      • Remove charging port flex.
      Ask FixBot
    11. Sony Xperia Z5 LCD Screen Replacement: step 11, image 1 of 2 Sony Xperia Z5 LCD Screen Replacement: step 11, image 2 of 2
      • Remove microphone.
      Ask FixBot
    12. Sony Xperia Z5 LCD Screen Replacement: step 12, image 1 of 2 Sony Xperia Z5 LCD Screen Replacement: step 12, image 2 of 2
      • Remove the metal bracket covering on the LCD screen flex.
      Ask FixBot
    13. Sony Xperia Z5 LCD Screen Replacement: step 13, image 1 of 3 Sony Xperia Z5 LCD Screen Replacement: step 13, image 2 of 3 Sony Xperia Z5 LCD Screen Replacement: step 13, image 3 of 3
      • The sticker underneath is strong, so use heat gun to soften it for a few minutes.
      • Remove LCD screen carefully.
      • Take extra care when prying along the bottom edge of the display to avoid damaging the display cable.
      Ask FixBot
    14. Sony Xperia Z5 LCD Screen Replacement: step 14, image 1 of 1
      • Done.
      Ask FixBot
47 other people completed this guide.
Lenka
2,408 Reputation
6 Guides authored
45 Guide Comments
Awesome guide. Helped me alot. However i got blank screen after installing the new screen. Dont panic. You must replace the tape that covers the lcd filters. If you dont the metal plate will bridge the connections and the LCD will not display. I thought i broke the LCD however just replaced the tape off the original LCD and BOOM!
Kiwi phone repairs - Reply Share
What are the filters? I have a repair shop and all screens are like these. Can't find them anywhere.
Johnny - Reply Share
Hi, you need to reuse the black tape sticked on the original flex cable to cover the filters on the replacement part.
Adrien Ould Madi - Reply Share
I would like also to know which tape you replaced.
Patrick - Reply Share
What r the lcd filters as I have replaced a screen on Sony z5 on 2 phones now and the backlight isn't working on both phones but u can see that the screens r working any help would be great thanks
Barry - Reply Share
Past 24 Hours: 9
Past 7 Days: 38
Past 30 Days: 143
All Time: 103,020
