Up to 20% off select tools
Sony Xperia Z5 Compact Screen Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
64
All Time:
1,446
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Difficult
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
Introduction
Go to step 1 ↓
This guide provides step by step instructions on how to properly replace the screen of the Sony Xperia Z5 Compact.
    1. Sony Xperia Z5 Compact Screen Replacement, Charging port flex: step 1, image 1 of 2 Sony Xperia Z5 Compact Screen Replacement, Charging port flex: step 1, image 2 of 2
      • Power off and remove SIM card tray.
      Ask FixBot
    2. Sony Xperia Z5 Compact Screen Replacement: step 2, image 1 of 3 Sony Xperia Z5 Compact Screen Replacement: step 2, image 2 of 3 Sony Xperia Z5 Compact Screen Replacement: step 2, image 3 of 3
      • Heat up the back cover to soften the adhesive.
      • Place the suction cup to open a gap from top side, then insert guitar picks and slide it to cut the adhesive underneath.
      • Remove back cover.
      Ask FixBot
    3. Sony Xperia Z5 Compact Screen Replacement: step 3, image 1 of 2 Sony Xperia Z5 Compact Screen Replacement: step 3, image 2 of 2
      • Remove all 10 Phillips screws.
      • Disconnect NFC clip and flashlight clip.
      Ask FixBot
    4. Sony Xperia Z5 Compact Screen Replacement: step 4, image 1 of 3 Sony Xperia Z5 Compact Screen Replacement: step 4, image 2 of 3 Sony Xperia Z5 Compact Screen Replacement: step 4, image 3 of 3
      • Remove the plastic bracket.
      • Pry up and remove back frame.
      Ask FixBot
    5. Sony Xperia Z5 Compact Screen Replacement: step 5, image 1 of 3 Sony Xperia Z5 Compact Screen Replacement: step 5, image 2 of 3 Sony Xperia Z5 Compact Screen Replacement: step 5, image 3 of 3
      • Remove front camera.
      Ask FixBot
    6. Sony Xperia Z5 Compact Screen Replacement: step 6, image 1 of 3 Sony Xperia Z5 Compact Screen Replacement: step 6, image 2 of 3 Sony Xperia Z5 Compact Screen Replacement: step 6, image 3 of 3
      • Remove rear camera.
      Ask FixBot
    7. Sony Xperia Z5 Compact Screen Replacement: step 7, image 1 of 3 Sony Xperia Z5 Compact Screen Replacement: step 7, image 2 of 3 Sony Xperia Z5 Compact Screen Replacement: step 7, image 3 of 3
      • Remove loudspeaker.
      Ask FixBot
    8. Sony Xperia Z5 Compact Screen Replacement: step 8, image 1 of 3 Sony Xperia Z5 Compact Screen Replacement: step 8, image 2 of 3 Sony Xperia Z5 Compact Screen Replacement: step 8, image 3 of 3
      • Release charging port connector.
      • Remove plastic protective bar.
      • Pry up motherboard assembly from this side. There are three flex connectors connecting the motherboard underneath. So pry up the motherboard assembly gently.
      Ask FixBot
    9. Sony Xperia Z5 Compact Screen Replacement: step 9, image 1 of 1
      • Remove charging port flex.
      Ask FixBot
    1. Sony Xperia Z5 Compact Screen Replacement, Screen: step 10, image 1 of 2 Sony Xperia Z5 Compact Screen Replacement, Screen: step 10, image 2 of 2
      • Remove the motherboard/battery assembly.
      • Using a spudger, release the battery connector from the motherboard.
      Ask FixBot
    2. Sony Xperia Z5 Compact Screen Replacement: step 11, image 1 of 2 Sony Xperia Z5 Compact Screen Replacement: step 11, image 2 of 2
      • Using a suction cup, create a space between the screen and the phone.
      • Using an opening tool, pry the LCD screen up.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 64
All Time: 1,446
