Sony Xperia Z5 Compact Motherboard Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
86
All Time:
1,941
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes
Difficulty: Difficult
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
The motherboard is the central hub of communication between all of the components in the device. If one or more components are failing in your device, you should consider replacing the motherboard. Use this guide to replace the motherboard in your device.
Parts
Tools
    1. Sony Xperia Z5 Compact Motherboard Replacement, Charging port flex: step 1, image 1 of 2 Sony Xperia Z5 Compact Motherboard Replacement, Charging port flex: step 1, image 2 of 2
      • Power off and remove SIM card tray.
      Ask FixBot
    2. Sony Xperia Z5 Compact Motherboard Replacement: step 2, image 1 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 2, image 2 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 2, image 3 of 3
      • Heat up the back cover to soften the adhesive.
      • Place the suction cup to open a gap from top side, then insert guitar picks and slide it to cut the adhesive underneath.
      • Remove back cover.
      Ask FixBot
    3. Sony Xperia Z5 Compact Motherboard Replacement: step 3, image 1 of 2 Sony Xperia Z5 Compact Motherboard Replacement: step 3, image 2 of 2
      • Remove all 10 Phillips screws.
      • Disconnect NFC clip and flashlight clip.
      Ask FixBot
    4. Sony Xperia Z5 Compact Motherboard Replacement: step 4, image 1 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 4, image 2 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 4, image 3 of 3
      • Remove the plastic bracket.
      • Pry up and remove back frame.
      Ask FixBot
    5. Sony Xperia Z5 Compact Motherboard Replacement: step 5, image 1 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 5, image 2 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 5, image 3 of 3
      • Remove front camera.
      Ask FixBot
    6. Sony Xperia Z5 Compact Motherboard Replacement: step 6, image 1 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 6, image 2 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 6, image 3 of 3
      • Remove rear camera.
      Ask FixBot
    7. Sony Xperia Z5 Compact Motherboard Replacement: step 7, image 1 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 7, image 2 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 7, image 3 of 3
      • Remove loudspeaker.
      Ask FixBot
    8. Sony Xperia Z5 Compact Motherboard Replacement: step 8, image 1 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 8, image 2 of 3 Sony Xperia Z5 Compact Motherboard Replacement: step 8, image 3 of 3
      • Release charging port connector.
      • Remove plastic protective bar.
      • Pry up motherboard assembly from this side. There are three flex connectors connecting the motherboard underneath. So pry up the motherboard assembly gently.
      Ask FixBot
    9. Sony Xperia Z5 Compact Motherboard Replacement: step 9, image 1 of 1
      • Remove charging port flex.
      Ask FixBot
    1. Sony Xperia Z5 Compact Motherboard Replacement, Motherboard: step 10, image 1 of 2 Sony Xperia Z5 Compact Motherboard Replacement, Motherboard: step 10, image 2 of 2
      • Remove the motherboard/battery assembly.
      • Using a spudger, release the battery connector from the motherboard.
      Ask FixBot
    2. Sony Xperia Z5 Compact Motherboard Replacement: step 11, image 1 of 2 Sony Xperia Z5 Compact Motherboard Replacement: step 11, image 2 of 2
      • Slowly pull out the two battery tapes located on the right side of the battery.
      • Remove the battery from the motherboard.
      Ask FixBot
    3. Sony Xperia Z5 Compact Motherboard Replacement: step 12, image 1 of 2 Sony Xperia Z5 Compact Motherboard Replacement: step 12, image 2 of 2
      • Place two pieces of binding tape on the center of the motherboard.
      • Reattach the battery to the motherboard.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 86
All Time: 1,941
