Sony Xperia Z5 Compact Battery Replacement
    1. Sony Xperia Z5 Compact Battery Replacement, Battery: step 1, image 1 of 2 Sony Xperia Z5 Compact Battery Replacement, Battery: step 1, image 2 of 2
      • Power off and remove SIM card tray.
      Ask FixBot
    2. Sony Xperia Z5 Compact Battery Replacement: step 2, image 1 of 3 Sony Xperia Z5 Compact Battery Replacement: step 2, image 2 of 3 Sony Xperia Z5 Compact Battery Replacement: step 2, image 3 of 3
      • Heat up the back cover to soften the adhesive.
      • Place the suction cup to open a gap from top side, then insert guitar picks and slide it to cut the adhesive underneath.
      • Remove back cover.
      Ask FixBot
    3. Sony Xperia Z5 Compact Battery Replacement: step 3, image 1 of 2 Sony Xperia Z5 Compact Battery Replacement: step 3, image 2 of 2
      • Twist off 10 Phillips screws all.
      • Loosen NFC clip and flashlight clip.
      Ask FixBot
    4. Sony Xperia Z5 Compact Battery Replacement: step 4, image 1 of 3 Sony Xperia Z5 Compact Battery Replacement: step 4, image 2 of 3 Sony Xperia Z5 Compact Battery Replacement: step 4, image 3 of 3
      • Remove the plastic bracket.
      • Pry up and remove back frame.
      Ask FixBot
    5. Sony Xperia Z5 Compact Battery Replacement: step 5, image 1 of 3 Sony Xperia Z5 Compact Battery Replacement: step 5, image 2 of 3 Sony Xperia Z5 Compact Battery Replacement: step 5, image 3 of 3
      • Remove front camera.
      Ask FixBot
    6. Sony Xperia Z5 Compact Battery Replacement: step 6, image 1 of 3 Sony Xperia Z5 Compact Battery Replacement: step 6, image 2 of 3 Sony Xperia Z5 Compact Battery Replacement: step 6, image 3 of 3
      • Remove rear camera.
      Ask FixBot
    7. Sony Xperia Z5 Compact Battery Replacement: step 7, image 1 of 3 Sony Xperia Z5 Compact Battery Replacement: step 7, image 2 of 3 Sony Xperia Z5 Compact Battery Replacement: step 7, image 3 of 3
      • Remove loudspeaker.
      Ask FixBot
    8. Sony Xperia Z5 Compact Battery Replacement: step 8, image 1 of 3 Sony Xperia Z5 Compact Battery Replacement: step 8, image 2 of 3 Sony Xperia Z5 Compact Battery Replacement: step 8, image 3 of 3
      • Release charging port connector.
      • Remove plastic protective bar.
      • Pry up motherboard assembly from this side. There are three flex connectors connecting the motherboard underneath. So pry up the motherboard assembly gently.
      Ask FixBot
    9. Sony Xperia Z5 Compact Battery Replacement: step 9, image 1 of 3 Sony Xperia Z5 Compact Battery Replacement: step 9, image 2 of 3 Sony Xperia Z5 Compact Battery Replacement: step 9, image 3 of 3
      • Push audio jack out of the slot, no adhesive underneath.
      • Release LCD flex connector and main flex connector. Use a small flat tool to flip up the white edge of the connector to release tension on the end of the flex cable. Then the flex cable should slide out without any resistance.
      • Separate motherboard assembly from middle housing.
      Ask FixBot
    10. Sony Xperia Z5 Compact Battery Replacement: step 10, image 1 of 2 Sony Xperia Z5 Compact Battery Replacement: step 10, image 2 of 2
      • Take away NFC antenna on battery.
      • Be aware that the NFC antenna is held by an adhesive and made of thin plastic. Remove it very carefully.
      Ask FixBot
    11. Sony Xperia Z5 Compact Battery Replacement: step 11, image 1 of 3 Sony Xperia Z5 Compact Battery Replacement: step 11, image 2 of 3 Sony Xperia Z5 Compact Battery Replacement: step 11, image 3 of 3
      • Release battery connector.
      • Pull straight out on the black ends of the battery adhesive strips until they come off.
      • Pry up and remove battery.
      Ask FixBot
    12. Sony Xperia Z5 Compact Battery Replacement: step 12, image 1 of 2 Sony Xperia Z5 Compact Battery Replacement: step 12, image 2 of 2
      • Place the new battery adhesive strips on the motherboard
      • Press the new battery in place
      • Follow all the steps in reverse to reassemble your phone
      Ask FixBot
26 other people completed this guide.
Witrigs
71,142 Reputation
377 Guides authored
18 Guide Comments
Will the device boot up with no error message after replacing it with new battery? Or do you need some programming before or after replacing it?
Christian Duane Co - Reply Share
There is no error when battery is changed.
Just successfully changed my battery without any issue. Booted up normally and able to do everything I was able to do before.
Thank you for the awesome guide :)
DANIEL SOESILO - Reply Share
The Sony Experia Z5 Compact is water and dust proof. Will heating the back after putting it back on reseal the phone - or is there another step that needs to be added?
Steven Cox - Reply Share
You can watch the repair video on youtube: https://www.youtube.com/user/lagaiPhoneS..., but I fixed it here https://lagaiphone.se/shop/sony-z5-compa... they used the adhesive but no water resistant warranty after repair. so far so good!
LagaiPhone.se - Reply Share
Pretty annoying, this mentions NOTHING about the battery adhesive strips to order separately, and neither of the “things to buy” come with them. I just replaced my battery, but it’s just flopping around inside at the moment. Where do I order the battery adhesive strips to adhere the battery to the motherboard? Note for others doing this too, you NEED the adhesive strips separately beside the battery and the back adhesive!
michael - Reply Share
Past 24 Hours: 5
Past 7 Days: 31
Past 30 Days: 189
All Time: 77,153
