Sony Xperia Z3 Compact Rear Camera Replacement
    1. Sony Xperia Z3 Compact Rear Camera Replacement, Heat the cover glue: step 1, image 1 of 1
      • Heat up along the edges of the cover to soften the glue.
      • Ideal temperature is around 120 - 150 °C for 60 seconds.
      Ask FixBot
    2. Sony Xperia Z3 Compact Rear Camera Replacement: step 2, image 1 of 1
      • Place a suction cup on the back cover and pull to open a gap.
      • Insert a guitar pick into the gap and slide it around the corner of the back cover to cut the adhesive sticker.
      Ask FixBot
    3. Sony Xperia Z3 Compact Rear Camera Replacement: step 3, image 1 of 1
      • Finally, remove the back cover.
      • Be careful, the back cover is fragile and can break.
      • It can be a good idea to wear protective glasses. If the glass shatters, it could enter your eye.
      Ask FixBot
    1. Sony Xperia Z3 Compact Rear Camera Replacement, Rear Camera: step 4, image 1 of 3 Sony Xperia Z3 Compact Rear Camera Replacement, Rear Camera: step 4, image 2 of 3 Sony Xperia Z3 Compact Rear Camera Replacement, Rear Camera: step 4, image 3 of 3
      • Disconnect the NFC antenna.
      • Unscrew the screws holding the black midframe in place.
      • Remove midframe.
      Ask FixBot
    2. Sony Xperia Z3 Compact Rear Camera Replacement: step 5, image 1 of 3 Sony Xperia Z3 Compact Rear Camera Replacement: step 5, image 2 of 3 Sony Xperia Z3 Compact Rear Camera Replacement: step 5, image 3 of 3
      • Disconnect the battery flex connector.
      • Remove rear camera bracket.
      Ask FixBot
    3. Sony Xperia Z3 Compact Rear Camera Replacement: step 6, image 1 of 3 Sony Xperia Z3 Compact Rear Camera Replacement: step 6, image 2 of 3 Sony Xperia Z3 Compact Rear Camera Replacement: step 6, image 3 of 3
      • components on the mainboard are fragile, be careful in the next step.
      • disconnect the flat top cable with a spudger
      Ask FixBot
17 other people completed this guide.
Sophia
43,911 Reputation
62 Guides authored
4 Guide Comments
Hi i just replaced myxperia z3 compact camera using your Step by step guide. ( Great job on this by the way!) but unfortunately my rear camera is still showing a black screen. What else could be causing this, either hardware or software related?
Atiyeh - Reply Share
Same - however Sony seem to be aware of the issue and are not honoring warranty on the device despite being less than 2 years old which is why I am trying this.. Rather annoying. An otherwise usable phone is resigned to the parts box due to an issue with the rear facing camera.
gary mckie - Reply Share
Do I need additional adhesive to reassemble the phone, or the old one will work just fine?
Giacomo Ciani - Reply Share
You'll need a new adhesive pad.
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 112
All Time: 16,595
