Sony Xperia Z3 Compact Battery Replacement
    1. Sony Xperia Z3 Compact Battery Replacement, Sony Xperia Z3 Compact Battery Replacement: step 1, image 1 of 3 Sony Xperia Z3 Compact Battery Replacement, Sony Xperia Z3 Compact Battery Replacement: step 1, image 2 of 3 Sony Xperia Z3 Compact Battery Replacement, Sony Xperia Z3 Compact Battery Replacement: step 1, image 3 of 3
      • Heat the back cover of your Xperia Z3 Compact with an iOpener to loosen the adhesive underneath.
      • Lift up the back cover with a suction handle and put an opening pick in the gap.
      • Move the pick carefully around the edges to loosen the adhesive on every side of the phone.
      • Now you can pull up the back cover with the suction handle.
      Ask FixBot
    2. Sony Xperia Z3 Compact Battery Replacement: step 2, image 1 of 2 Sony Xperia Z3 Compact Battery Replacement: step 2, image 2 of 2
      • Use a tweezer to remove the model label which is hooked in the right side of the frame.
      • Undo the flex cable of the NFC antenna with a tweezer.
      Ask FixBot
    3. Sony Xperia Z3 Compact Battery Replacement: step 3, image 1 of 2 Sony Xperia Z3 Compact Battery Replacement: step 3, image 2 of 2
      • Unscrew the following screws which hold down the mid frame of the Sony Xperia Z3 Compact.
      • Two 2.7 mm Phillips #000
      • Three 2.5 mm Phillips #000
      • Use a Spudger to lift up the mid frame on each side.
      • Be careful and patient, the plastic mid frame is fragile and might break if bent too hard.
      Ask FixBot
    4. Sony Xperia Z3 Compact Battery Replacement: step 4, image 1 of 3 Sony Xperia Z3 Compact Battery Replacement: step 4, image 2 of 3 Sony Xperia Z3 Compact Battery Replacement: step 4, image 3 of 3
      • Declamp the metal bracket which holds down the flex connector of the rear camera.
      • Unplug the flex connector of the rear camera and lift it out of its recess.
      Ask FixBot
    5. Sony Xperia Z3 Compact Battery Replacement: step 5, image 1 of 2 Sony Xperia Z3 Compact Battery Replacement: step 5, image 2 of 2
      • Use a Spudger to unplug the headphone jack and sensor cable connector.
      • Unscrew the single 2.5 mm Phillips #000 screw on the upper left side of the motherboard.
      Ask FixBot
    6. Sony Xperia Z3 Compact Battery Replacement: step 6, image 1 of 3 Sony Xperia Z3 Compact Battery Replacement: step 6, image 2 of 3 Sony Xperia Z3 Compact Battery Replacement: step 6, image 3 of 3
      • Unplug the battery and display flex connectors.
      • Open the compartments for the SIM card and the micro SD card and remove them.
      Ask FixBot
    7. Sony Xperia Z3 Compact Battery Replacement: step 7, image 1 of 3 Sony Xperia Z3 Compact Battery Replacement: step 7, image 2 of 3 Sony Xperia Z3 Compact Battery Replacement: step 7, image 3 of 3
      • Use a Spudger to slightly lift up the motherboard.
      • Be careful! You need to thread the display flex cable through a gap in the motherboard while lifting it up. It is also connected to the vibration motor, which still sticks to the phone.
      • Take especially care of the two black connectors on the side of the battery. They break off easily during the removal of the motherboard.
      • Use a tweezer to take out the vibration motor and then remove the motherboard completely.
      Ask FixBot
    8. Sony Xperia Z3 Compact Battery Replacement: step 8, image 1 of 3 Sony Xperia Z3 Compact Battery Replacement: step 8, image 2 of 3 Sony Xperia Z3 Compact Battery Replacement: step 8, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Gently pull out both of the black straps with the adhesive tabs underneath the battery.
      • Never pull out the straps upwards but always sideways. It can easily happen that you rupture the adhesive tabs. In this case use a plastic card to pry off the battery carefully,Use a little bit of heat if necessary!
      • Now you can remove the battery from the motherboard easily.
      Ask FixBot
    9. Sony Xperia Z3 Compact Battery Replacement: step 9, image 1 of 3 Sony Xperia Z3 Compact Battery Replacement: step 9, image 2 of 3 Sony Xperia Z3 Compact Battery Replacement: step 9, image 3 of 3
      • Warm up the NFC antenna a little bit to loosen the adhesive underneath.
      • Carefully peel it off the battery. If the adhesive starts to crumble use a plastic card to loosen the adhesive.
      Ask FixBot
24 other people completed this guide.
Tobias Isakeit
135,840 Reputation
189 Guides authored
10 Guide Comments
Thank you Tobias !
My Z3 compact starts now his second life :)
Guy Hard - Reply Share
Thank you for repairing your phone and giving it a second chance.
Tobias Isakeit - Reply Share
Where do I need the Back Cover Adhesive Strips for?
Visser - Reply Share
The guide doesn’t mention that one needs new adhesive for the battery (the one I bought isn’t sold with it). It would therefore be wise to mention what kind of adhesive (two-sided, what thckness, etc.)
axel - Reply Share
Double sided tape is enough to keep it in place, as the back cover and midframe holds everything down for extra reinforcement. Sony sure makes their smartphones !&&* to repair, but that’s another rant.
William Nephew - Reply Share
Past 24 Hours: 4
Past 7 Days: 46
Past 30 Days: 182
All Time: 44,577
