Up to 20% off select tools
Sony Xperia Z3 Compact Back Cover Replacement
Views: 48K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
115
All Time:
47,748
Comments: 9
1 comment on steps, 8 guide comments.
Go to guide comments
Completed: 38
38 people have marked this guide "completed." Will you be next?
Favorites: 21
21 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 45 minutes
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to remove the back cover of the Sony Xperia Z3 Compact.
    1. Sony Xperia Z3 Compact Back Cover Replacement, Heat the cover glue: step 1, image 1 of 1
      • Heat up along the edges of the cover to soften the glue.
      • Ideal temperature is around 120 - 150 °C for 60 seconds.
      Ask FixBot
    2. Sony Xperia Z3 Compact Back Cover Replacement: step 2, image 1 of 1
      • Place a suction cup on the back cover and pull to open a gap.
      • Insert a guitar pick into the gap and slide it around the corner of the back cover to cut the adhesive sticker.
      Ask FixBot
    3. Sony Xperia Z3 Compact Back Cover Replacement: step 3, image 1 of 1
      • Finally, remove the back cover.
      • Be careful, the back cover is fragile and can break.
      • It can be a good idea to wear protective glasses. If the glass shatters, it could enter your eye.
      Ask FixBot
38 other people completed this guide.
Author
with
Sophia
43,919 Reputation
62 Guides authored
8 Guide Comments
I think this guide shows how to open a phone that's already been opened. I have seen another that showed all the glue between the battery and the back cover that can take a lot of effort to remove, plus once done then (if it was before) it will not longer be waterproof.
Paul - Reply Share
I replaced battery cover and I heat up new one. It looks like it become waterproof again.
Vladimir Gorshunov - Reply Share
It will no longer be waterproof, unless you are using the exact same quality and amount of adhesive as the original one, and you press the back glass to the phone as hard as it was before.
If not, then it is hardly waterproof.
Thingalong - Reply Share
I used a domestic hair dryer for about 2 minutes to heat the back of the phone which softened the glue enough for the rear panel to be removed. A layer of glue remained around the frame. The replacement part also had a gummed edge and stuck quite firmly without needing any pressure.
I reheated the rear to soften the new glue and then held the phone in two small clamps gently but firmly until the phone had cooled (overnight as it was convenient).
The phone is waterproof.
IanW - Reply Share
Do not forget to clean the phone (remove the rest of the glue sticking on the phone). It will fit better with no old glue.
duesseldorfhahn - Reply Share
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 115
All Time: 47,748
