Sony Xperia Z3 Back Cover Replacement
    1. Sony Xperia Z3 Back Cover Replacement, Back Cover: step 1, image 1 of 3 Sony Xperia Z3 Back Cover Replacement, Back Cover: step 1, image 2 of 3 Sony Xperia Z3 Back Cover Replacement, Back Cover: step 1, image 3 of 3
      • Heat the back cover of your Xperia Z3 to loosen the adhesive underneath.
      • If you use an iOpener, follow these instructions for use.
      • Lift up the back cover with a suction handle and put an opening pick in the gap.
      • Move the pick carefully around the edges to loosen the adhesive on every side of the phone.
      • Don't put the pick in too deep under the back cover to not damage any parts inside the phone.
      Ask FixBot
    2. Sony Xperia Z3 Back Cover Replacement: step 2, image 1 of 2 Sony Xperia Z3 Back Cover Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • There are two adhesive strips in the center of the phone connecting the rear case to the battery, you'll need to remove them to open the phone.
      • When the edges of the cover are free from adhesive, tilt it to allow access to the battery tabs.
      • Use tweezers to pull the two black adhesive strips out of the phone but don't pull just yet.
      Ask FixBot
    3. Sony Xperia Z3 Back Cover Replacement: step 3, image 1 of 2 Sony Xperia Z3 Back Cover Replacement: step 3, image 2 of 2
      Plastic Cards
      $2.99
      Buy
      • Gently pull out both of the adhesive tabs out of the phone, parallel to the rear cover.
      • If the adhesive tabs break, try to use a thin flat plastic tool such as a plastic card to remove the last of the adhesive. If the adhesive is stubborn, heat it with an iOpener or hair dryer and pry again.
      Ask FixBot
    4. Sony Xperia Z3 Back Cover Replacement: step 4, image 1 of 2 Sony Xperia Z3 Back Cover Replacement: step 4, image 2 of 2
      • After pulling out the adhesive tabs, you can lift the back cover and remove it.
      Ask FixBot
7 other people completed this guide.
Tobias Isakeit
135,810 Reputation
189 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 29
Past 30 Days: 118
All Time: 7,084
