Up to 20% off select tools
Sony Xperia Z1s Screen Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
61
All Time:
808
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 55 minutes - 1 hour
Difficulty: Very difficult
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
If your device has a cracked or unresponsive touchscreen, you may need to replace your LCD touchscreen on your Sony Xperia Z1s device. In this guide, you will learn how to replace your Sony Xperia Z1s screen so that you may get the best performance out of your device.
Before beginning this guide, turn off your phone completely and remove it from any external power source.
Warning: Removing the back cover and screen without properly sealing the phone with new adhesive will make it no longer waterproof.
    1. Sony Xperia Z1s Screen Replacement, Battery: step 1, image 1 of 1
      • Insert the opening pick in the crease between the rear cover and the body of the phone.
      • Pry along the edge to lift and remove the back cover.
      Ask FixBot
    2. Sony Xperia Z1s Screen Replacement: step 2, image 1 of 1
      • Using the T4 Torx screwdriver, remove five 5 mm screws from the panel above the battery.
      • Remove the panel by grabbing its bottom edge and lifting upwards.
      Ask FixBot
    3. Sony Xperia Z1s Screen Replacement: step 3, image 1 of 1
      • Use the opening pick to pry off the battery flex cable.
      Ask FixBot
    4. Sony Xperia Z1s Screen Replacement: step 4, image 1 of 1
      • Using the T4 Torx screwdriver, remove two 5 mm screws from the bottom corners of the battery.
      Ask FixBot
    5. Sony Xperia Z1s Screen Replacement: step 5, image 1 of 1
      • Firmly press the suction cup onto the battery.
      • Pull the battery out using the suction handle.
      Ask FixBot
    1. Sony Xperia Z1s Screen Replacement, Motherboard: step 6, image 1 of 1
      • Use the opening pick to pry off the camera flex cable.
      • Continue to lift the flex cable upward until the camera pops out.
      Ask FixBot
    2. Sony Xperia Z1s Screen Replacement: step 7, image 1 of 1
      • Use the opening pick to pry off the three flex cables on the bottom of the motherboard.
      • Do the same for the one flex cable at the top of the motherboard.
      Ask FixBot
    3. Sony Xperia Z1s Screen Replacement: step 8, image 1 of 1
      • Use the opening pick to pry off the black plastic cover above the top of the motherboard.
      Ask FixBot
    4. Sony Xperia Z1s Screen Replacement: step 9, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers to lift up the motherboard.
      • If you are having trouble removing the motherboard, try lifting up the left edge first and sliding the rest of the motherboard out.
      Ask FixBot
    5. Sony Xperia Z1s Screen Replacement: step 10, image 1 of 1
      • Use a pair of tweezers to remove the pin connection on the motherboard.
      • Fully remove the motherboard from the device.
      Ask FixBot
    1. Sony Xperia Z1s Screen Replacement, LCD Screen: step 11, image 1 of 1
      • Using the T4 Torx screwdriver, unscrew the single 5 mm screw from the bottom left corner of the loudspeaker cover.
      Ask FixBot
    2. Sony Xperia Z1s Screen Replacement: step 12, image 1 of 1
      • Slide the opening pick under the edge of the loudspeaker cover.
      • Gently lift and pry up the loudspeaker cover.
      Ask FixBot
    3. Sony Xperia Z1s Screen Replacement: step 13, image 1 of 1
      • Use your fingers to slowly peel back the black flex cable in the middle of the phone until it is only connected at the bottom of the phone.
      Ask FixBot
    4. Sony Xperia Z1s Screen Replacement: step 14, image 1 of 1
      • Gently slide the opening pick underneath the screen.
      • Lift the opening pick upward to remove the screen.
      • If needed, use a heat gun to loosen the adhesive holding the screen by aiming it around the edge of the screen.
      Ask FixBot
Author
with
Emily Scruggs
127 Reputation
1 Guide authored
Clemson, Team 4-4, Hunter Fall 2021 Member of Clemson, Team 4-4, Hunter Fall 2021
CLEM-HUNTER-F21S4G4
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 61
All Time: 808
