Sony Xperia Z1s Motherboard Replacement
    1. Sony Xperia Z1s Motherboard Replacement, Battery: step 1, image 1 of 1
      • Insert the opening pick in the crease between the rear cover and the body of the phone.
      • Pry along the edge to lift and remove the back cover.
      Ask FixBot
    2. Sony Xperia Z1s Motherboard Replacement: step 2, image 1 of 1
      • Using the T4 Torx screwdriver, remove five 5 mm screws from the panel above the battery.
      • Remove the panel by grabbing its bottom edge and lifting upwards.
      Ask FixBot
    3. Sony Xperia Z1s Motherboard Replacement: step 3, image 1 of 1
      • Use the opening pick to pry off the battery flex cable.
      Ask FixBot
    4. Sony Xperia Z1s Motherboard Replacement: step 4, image 1 of 1
      • Using the T4 Torx screwdriver, remove two 5 mm screws from the bottom corners of the battery.
      Ask FixBot
    5. Sony Xperia Z1s Motherboard Replacement: step 5, image 1 of 1
      • Firmly press the suction cup onto the battery.
      • Pull the battery out using the suction handle.
      Ask FixBot
    1. Sony Xperia Z1s Motherboard Replacement, Motherboard: step 6, image 1 of 1
      • Use the opening pick to pry off the camera flex cable.
      • Continue to lift the flex cable upward until the camera pops out.
      Ask FixBot
    2. Sony Xperia Z1s Motherboard Replacement: step 7, image 1 of 1
      • Use the opening pick to pry off the three flex cables on the bottom of the motherboard.
      • Do the same for the one flex cable at the top of the motherboard.
      Ask FixBot
    3. Sony Xperia Z1s Motherboard Replacement: step 8, image 1 of 1
      • Use the opening pick to pry off the black plastic cover above the top of the motherboard.
      Ask FixBot
    4. Sony Xperia Z1s Motherboard Replacement: step 9, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers to lift up the motherboard.
      • If you are having trouble removing the motherboard, try lifting up the left edge first and sliding the rest of the motherboard out.
      Ask FixBot
    5. Sony Xperia Z1s Motherboard Replacement: step 10, image 1 of 1
      • Use a pair of tweezers to remove the pin connection on the motherboard.
      • Fully remove the motherboard from the device.
      Ask FixBot
Matthew Klengson
324 Reputation
2 Guides authored
Clemson, Team 4-4, Hunter Fall 2021 Member of Clemson, Team 4-4, Hunter Fall 2021
CLEM-HUNTER-F21S4G4
5 Members
57 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 29
All Time: 447
