Up to 20% off select tools
Sony Xperia Z1 Compact Screen Replacement
Views: 19K
View statistics:
Past 24 Hours:
5
Past 7 Days:
17
Past 30 Days:
102
All Time:
18,607
Comments: 5
5 guide comments.
Go to guide comments
Completed: 30
30 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 minutes
Difficulty: Easy
Community-Contributed Guide
Parts
Tools
    1. Sony Xperia Z1 Compact Screen Replacement, Apply heat: step 1, image 1 of 1
      • Apply heat to the edges.
      Ask FixBot
    2. Sony Xperia Z1 Compact Screen Replacement, Start prying: step 2, image 1 of 1
      • When the glue is warm slowly start prying from the top corner.
      Ask FixBot
    3. Sony Xperia Z1 Compact Screen Replacement, Add more heat if necessary: step 3, image 1 of 1
      • If the glue is cooled down heat more. Don't force it.
      Ask FixBot
    4. Sony Xperia Z1 Compact Screen Replacement, Cable: step 4, image 1 of 1
      • Remove the data cable from the phones body.
      Ask FixBot
    5. Sony Xperia Z1 Compact Screen Replacement, Testing new screen: step 5, image 1 of 1
      • Test if the new screen works properly.
      Ask FixBot
    6. Sony Xperia Z1 Compact Screen Replacement, The tape: step 6, image 1 of 1
      • If the screen works, remove the new screen and add the double sided tape
      Ask FixBot
    7. Sony Xperia Z1 Compact Screen Replacement, Connecting new screen: step 7, image 1 of 1
      • Connect the new screen to the phone.
      Ask FixBot
    8. Sony Xperia Z1 Compact Screen Replacement, Apply force: step 8, image 1 of 1
      • Now push town not to tight not to softly to the screen.
      • And that's it. You finished the screen replacement.
      Ask FixBot
30 other people completed this guide.
Author
with
jaanparker
952 Reputation
1 Guide authored
5 Guide Comments
There is a very good Youtube video of this. I think these are screenshots from it.
Andrew - Reply Share
Good video! Help me too! Thanks
Clodoaldo Castro - Reply Share
There is a thin, soft foam layer on the backside of the factory screen assembly, right behind the LCD backlight. This insulation foam is missing from most replacement screens. It can be peeled off relatively easily, but it will not stick easily onto the replacement LCD. I am not sure whether it is required at all, does anybody have experience and recommendations concerning this?
sinistre - Reply Share
My lcd burn before use Heat gun! Very sad!
Use t7000 glue for glueing screen back down,sure way of it not lifting off
Marcus Roach - Reply Share
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 102
All Time: 18,607
