Sony Xperia Z1 Compact Battery Replacement
    1. Sony Xperia Z1 Compact Battery Replacement, Back Cover: step 1, image 1 of 1
      • Heat along the edges of the back cover using a heat gun to soften the glue.
      Ask FixBot
    2. Sony Xperia Z1 Compact Battery Replacement: step 2, image 1 of 1
      • Attach the small suction cup to the back cover near the bottom of the phone.
      • Pull up on the suction cup and insert the plastic opening tool in between the back cover and the rest of the phone.
      Ask FixBot
    3. Sony Xperia Z1 Compact Battery Replacement: step 3, image 1 of 2 Sony Xperia Z1 Compact Battery Replacement: step 3, image 2 of 2
      • Move the spudger around the edge of the back cover to separate it from the black adhesive.
      • Separating the back cover from the rest of the phone ruins the adhesive which makes it no longer waterproof.
      Ask FixBot
    1. Sony Xperia Z1 Compact Battery Replacement, Battery: step 4, image 1 of 2 Sony Xperia Z1 Compact Battery Replacement, Battery: step 4, image 2 of 2
      • Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
      Ask FixBot
    2. Sony Xperia Z1 Compact Battery Replacement: step 5, image 1 of 2 Sony Xperia Z1 Compact Battery Replacement: step 5, image 2 of 2
      • Remove the single 1 x 3.0 mm screw holding the battery in using the JIS #00 screwdriver.
      Ask FixBot
    3. Sony Xperia Z1 Compact Battery Replacement: step 6, image 1 of 1
      • Pry the battery up from the ends using the plastic spudger until the battery pops out of the enclosure.
      Ask FixBot
    4. Sony Xperia Z1 Compact Battery Replacement: step 7, image 1 of 1
      • Remove the battery from the device
      Ask FixBot
12 other people completed this guide.
kinan badr
386 Reputation
1 Guide authored
3 Guide Comments
is there any reliable source for good replacement battery purchase?
Upendra Gandhi - Reply Share
What is the Ariel stuck on the battery ?
Tony - Reply Share
NFC Antenna. You should carefully transplant it to new battery, in case your new battery is without one (what is the case for most 3rd party batteries available)
Peter Pepo - Reply Share
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 135
All Time: 12,720
