Introduction
Over time, charging ports can wear out or become damaged. This can lead to inconsistent connections between the contacts of your phone and charging cable, causing slow or non-existent charging. This guide will help you swap out the faulty port of your Sony Xperia Z1 with a replacement and bring your phone’s charging capabilities back to normal.
Before you begin replacing the port, make sure the issue isn’t caused by a damaged cable, faulty power adapter, or debris inside the charging port. It’s also a good idea to confirm that the phone isn't limited by software or battery-related issues.
Once you’re ready to start, power off your phone and disconnect any cables.
With caution to hot temperatures, glide a heat gun over the outer edges of the phone bezel to soften the adhesive securing the back panel to the phone.
Tool used on this step:Halberd Spudger$2.99
Slowly slip the halberd spudger underneath the rest of the orange flex cable to carefully peel the adhesive portion away from the rest of the phone.
Tool used on this step:Tweezers$4.99
Use a T5 Torx screwdriver to remove the two screws on the long metal bracket along the left side of the phone.
Remove the metal cover with a pair of tweezers.
