Up to 20% off select tools
Sony Xperia XZ2 Front Camera Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
64
All Time:
1,704
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 9 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If the front camera on your Sony Xperia XZ2 is no longer working, it may need to be replaced. To replace the front camera use this guide. For this guide you will need a hair dryer, opening picks, angled tweezers, a spudger, and a Phillips #00 screwdriver.
Replacing the front camera requires removal of the LCD screen.
    1. Sony Xperia XZ2 Front Camera Replacement, LCD Screen: step 1, image 1 of 3 Sony Xperia XZ2 Front Camera Replacement, LCD Screen: step 1, image 2 of 3 Sony Xperia XZ2 Front Camera Replacement, LCD Screen: step 1, image 3 of 3
      • Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
      • The phone gets very hot and can hurt the user handling it.
      Ask FixBot
    2. Sony Xperia XZ2 Front Camera Replacement: step 2, image 1 of 3 Sony Xperia XZ2 Front Camera Replacement: step 2, image 2 of 3 Sony Xperia XZ2 Front Camera Replacement: step 2, image 3 of 3
      • Scrape all the glue from the inside edges by inserting opening picks into the bottom edge of the phone and working your way around the edges.
      • If the glue hardens and becomes difficult to move the plastic around the edges, reheat the phone.
      Ask FixBot
    3. Sony Xperia XZ2 Front Camera Replacement: step 3, image 1 of 2 Sony Xperia XZ2 Front Camera Replacement: step 3, image 2 of 2
      • Pry open the phone by inserting an opening pick under one of the edges and removing the screen.
      • The screen is still attached by a connector, so do not pull the pieces apart.
      Ask FixBot
    4. Sony Xperia XZ2 Front Camera Replacement: step 4, image 1 of 1
      Tool used on this step:
      $3.99
      Buy
      • Remove the bracket covering the connector by grabbing one side of the bracket with angled tweezers and gently pulling it off.
      Ask FixBot
    5. Sony Xperia XZ2 Front Camera Replacement: step 5, image 1 of 1
      • Gently remove the connector by using a spudger to pop it off.
      Ask FixBot
    1. Sony Xperia XZ2 Front Camera Replacement, Front Camera: step 6, image 1 of 1
      • Take out the twelve 3.5mm screws using the Phillips #00 screwdriver.
      • Remove the one 3 mm Phillips #00 screws.
      • Remove the two 1mm Phillips #00 screws.
      • Fifteen screws should be removed in total in this step. (Not all the screws are visible in the picture.)
      Ask FixBot
    2. Sony Xperia XZ2 Front Camera Replacement: step 7, image 1 of 1
      • Lift the metal screen shield out of the phone.
      Ask FixBot
    3. Sony Xperia XZ2 Front Camera Replacement: step 8, image 1 of 3 Sony Xperia XZ2 Front Camera Replacement: step 8, image 2 of 3 Sony Xperia XZ2 Front Camera Replacement: step 8, image 3 of 3
      • Use the spudger to pop off the plastic protector.
      Ask FixBot
    4. Sony Xperia XZ2 Front Camera Replacement: step 9, image 1 of 1
      • Gently pry up the battery flex connector using the spudger.
      Ask FixBot
Author
with
Chloe
229 Reputation
1 Guide authored
Cal Poly, Team S19-G5, White Winter 2019 Member of Cal Poly, Team S19-G5, White Winter 2019
CPSU-WHITE-W19S19G5
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 64
All Time: 1,704
