Sony Xperia XZ Premium Front Camera Replacement
    1. Sony Xperia XZ Premium Front Camera Replacement, Back Panel: step 1, image 1 of 1
      • Place a heated iOpener on the back panel of the phone to melt the adhesive inside.
      • The iOpener or your desired heat source can be very hot and can heat up the phone, so make sure you do not burn yourself.
      • Follow this guide for directions on using the iOpener.
      Ask FixBot
    2. Sony Xperia XZ Premium Front Camera Replacement: step 2, image 1 of 1
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Slide a thin plastic card under the back panel and around the perimeter of the phone to remove the adhesive.
      Ask FixBot
    3. Sony Xperia XZ Premium Front Camera Replacement: step 3, image 1 of 1
      • Take hold of the back panel with your fingers and remove.
      Ask FixBot
    1. Sony Xperia XZ Premium Front Camera Replacement, Front Camera: step 4, image 1 of 1
      • Remove the two bottom left 3.9 mm Phillips #000 screws.
      Ask FixBot
    2. Sony Xperia XZ Premium Front Camera Replacement: step 5, image 1 of 1
      • Insert the spudger under the bottom left frame and lift, try to lift vertically to wedge it out.
      Ask FixBot
    3. Sony Xperia XZ Premium Front Camera Replacement: step 6, image 1 of 1
      • Grab hold of the bottom left frame and lift out carefully.
      Ask FixBot
    4. Sony Xperia XZ Premium Front Camera Replacement: step 7, image 1 of 1
      • Insert a spudger under the tab above the camera and lift to disconnect it.
      Ask FixBot
    5. Sony Xperia XZ Premium Front Camera Replacement: step 8, image 1 of 1
      • Grab hold of the tab with your fingers.
      Ask FixBot
    6. Sony Xperia XZ Premium Front Camera Replacement: step 9, image 1 of 1
      • Lift the camera from the phone by the tab.
      Ask FixBot
Gelene Amog
1,189 Reputation
5 Guides authored
Cal Poly, Team S18-G2, Livingston Spring 2018 Member of Cal Poly, Team S18-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G2
5 Members
72 Guides authored
1 Guide Comment
The name of this tutorial is incorrect.
Gavin - Reply Share
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 70
All Time: 2,717
