Sony Xperia XZ Premium Frame Replacement
    1. Sony Xperia XZ Premium Frame Replacement, Back Panel: step 1, image 1 of 1
      • Place a heated iOpener on the back panel of the phone to melt the adhesive inside.
      • The iOpener or your desired heat source can be very hot and can heat up the phone, so make sure you do not burn yourself.
      • Follow this guide for directions on using the iOpener.
      Ask FixBot
    2. Sony Xperia XZ Premium Frame Replacement: step 2, image 1 of 1
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Slide a thin plastic card under the back panel and around the perimeter of the phone to remove the adhesive.
      Ask FixBot
    3. Sony Xperia XZ Premium Frame Replacement: step 3, image 1 of 1
      • Take hold of the back panel with your fingers and remove.
      Ask FixBot
    1. Sony Xperia XZ Premium Frame Replacement, Frame: step 4, image 1 of 1
      • Orient the phone horizontally with the front screen facing down and the camera on the bottom left corner.
      Ask FixBot
    2. Sony Xperia XZ Premium Frame Replacement: step 5, image 1 of 2 Sony Xperia XZ Premium Frame Replacement: step 5, image 2 of 2
      • Remove nine 3.9mm Phillips #000 screws.
      • Make sure to turn carefully in the counter-clockwise direction or you may wear out the thread and shape of the screws. You will not be able to remove the screws once they are damaged!
      • When unscrewing, remember "Left Loosey, Righty Tighty!"
      Ask FixBot
    3. Sony Xperia XZ Premium Frame Replacement: step 6, image 1 of 1
      • Place the spudger under the top left corner frame piece and lift to loosen.
      Ask FixBot
    4. Sony Xperia XZ Premium Frame Replacement: step 7, image 1 of 1
      • Grab hold of the top left frame piece with your fingers and gently wiggle and lift to remove.
      Ask FixBot
    5. Sony Xperia XZ Premium Frame Replacement: step 8, image 1 of 1
      • Place the spudger under the bottom left frame piece and lift to loosen it.
      Ask FixBot
    6. Sony Xperia XZ Premium Frame Replacement: step 9, image 1 of 1
      • Grab hold of bottom left frame piece with your fingers and lift gently.
      • When dislodging the left frame piece, carefully wiggle the piece while lifting it vertically to prevent any damage to the wedges on the frame. This applies for all of the other frame pieces you will remove after this step!
      Ask FixBot
    7. Sony Xperia XZ Premium Frame Replacement: step 10, image 1 of 1
      • Place the spudger under the top right frame piece and lift to loosen it.
      Ask FixBot
    8. Sony Xperia XZ Premium Frame Replacement: step 11, image 1 of 1
      • Grab hold of the top right frame piece with your fingers and lift.
      Ask FixBot
4 other people completed this guide.
Gelene Amog
1,189 Reputation
5 Guides authored
Cal Poly, Team S18-G2, Livingston Spring 2018 Member of Cal Poly, Team S18-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G2
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 49
All Time: 3,928
