Sony Xperia XZ Premium Battery Replacement
    1. Sony Xperia XZ Premium Battery Replacement, Back Panel: step 1, image 1 of 1
      • Place a heated iOpener on the back panel of the phone to melt the adhesive inside.
      • The iOpener or your desired heat source can be very hot and can heat up the phone, so make sure you do not burn yourself.
      • Follow this guide for directions on using the iOpener.
      Ask FixBot
    2. Sony Xperia XZ Premium Battery Replacement: step 2, image 1 of 1
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Slide a thin plastic card under the back panel and around the perimeter of the phone to remove the adhesive.
      Ask FixBot
    3. Sony Xperia XZ Premium Battery Replacement: step 3, image 1 of 1
      • Take hold of the back panel with your fingers and remove.
      Ask FixBot
    1. Sony Xperia XZ Premium Battery Replacement, Frame: step 4, image 1 of 1
      • Orient the phone horizontally with the front screen facing down and the camera on the bottom left corner.
      Ask FixBot
    2. Sony Xperia XZ Premium Battery Replacement: step 5, image 1 of 2 Sony Xperia XZ Premium Battery Replacement: step 5, image 2 of 2
      • Remove nine 3.9mm Phillips #000 screws.
      • Make sure to turn carefully in the counter-clockwise direction or you may wear out the thread and shape of the screws. You will not be able to remove the screws once they are damaged!
      • When unscrewing, remember "Left Loosey, Righty Tighty!"
      Ask FixBot
    3. Sony Xperia XZ Premium Battery Replacement: step 6, image 1 of 1
      • Place the spudger under the top left corner frame piece and lift to loosen.
      Ask FixBot
    4. Sony Xperia XZ Premium Battery Replacement: step 7, image 1 of 1
      • Grab hold of the top left frame piece with your fingers and gently wiggle and lift to remove.
      Ask FixBot
    5. Sony Xperia XZ Premium Battery Replacement: step 8, image 1 of 1
      • Place the spudger under the bottom left frame piece and lift to loosen it.
      Ask FixBot
    6. Sony Xperia XZ Premium Battery Replacement: step 9, image 1 of 1
      • Grab hold of bottom left frame piece with your fingers and lift gently.
      • When dislodging the left frame piece, carefully wiggle the piece while lifting it vertically to prevent any damage to the wedges on the frame. This applies for all of the other frame pieces you will remove after this step!
      Ask FixBot
    7. Sony Xperia XZ Premium Battery Replacement: step 10, image 1 of 1
      • Place the spudger under the top right frame piece and lift to loosen it.
      Ask FixBot
    8. Sony Xperia XZ Premium Battery Replacement: step 11, image 1 of 1
      • Grab hold of the top right frame piece with your fingers and lift.
      Ask FixBot
    1. Sony Xperia XZ Premium Battery Replacement, Motherboard: step 12, image 1 of 1
      • Insert your nail under the top left connector and push to disconnect it.
      Ask FixBot
    2. Sony Xperia XZ Premium Battery Replacement: step 13, image 1 of 1
      • Grab hold of the metal part of the connector with your fingers and lift.
      Ask FixBot
    3. Sony Xperia XZ Premium Battery Replacement: step 14, image 1 of 1
      • Insert your nail under the metal part of the bottom left connector.
      Ask FixBot
    4. Sony Xperia XZ Premium Battery Replacement: step 15, image 1 of 1
      • Push the bottom left connector with your finger to disconnect it.
      Ask FixBot
    5. Sony Xperia XZ Premium Battery Replacement: step 16, image 1 of 1
      • Insert your nail under the center topmost connector and push to loosen it.
      Ask FixBot
    6. Sony Xperia XZ Premium Battery Replacement: step 17, image 1 of 1
      • Grab hold of the top connector with your fingers and lift to disconnect it.
      Ask FixBot
    7. Sony Xperia XZ Premium Battery Replacement: step 18, image 1 of 1
      • Insert your nail under the metal tab of the connector above the battery and push to loosen it.
      Ask FixBot
    8. Sony Xperia XZ Premium Battery Replacement: step 19, image 1 of 1
      • Pull the metal tab of the connector towards you with your fingers to disconnect the pins.
      Ask FixBot
    9. Sony Xperia XZ Premium Battery Replacement: step 20, image 1 of 1
      • Insert spudger in the gap above the battery and lift to loosen the motherboard.
      • Use the spudger to slide under the edges of the motherboard if the motherboard does not seem to loosen after the above step.
      Ask FixBot
    10. Sony Xperia XZ Premium Battery Replacement: step 21, image 1 of 1
      • Insert the spudger in the gap between the motherboard and the left side of the battery to further lift out the motherboard.
      Ask FixBot
    11. Sony Xperia XZ Premium Battery Replacement: step 22, image 1 of 1
      • Grab hold of the motherboard with your fingers and lift it out of the phone gently.
      Ask FixBot
    1. Sony Xperia XZ Premium Battery Replacement, Battery: step 23, image 1 of 1
      • Insert the spudger under the battery and push to loosen it from the adhesive.
      • The adhesive under the battery is very strong and is concentrated on the very left and very right underneath the battery. You may have to use a good amount of force to dislodge it. Do not worry if you hear cracking noises as you dislodge it.
      Ask FixBot
    2. Sony Xperia XZ Premium Battery Replacement: step 24, image 1 of 1
      • Insert and push the spudger underneath the other sides of the battery to further loosen it.
      Ask FixBot
    3. Sony Xperia XZ Premium Battery Replacement: step 25, image 1 of 1
      Plastic Cards
      $2.99
      Buy
      • Use the plastic card to push under the battery to further remove the adhesive.
      Ask FixBot
    4. Sony Xperia XZ Premium Battery Replacement: step 26, image 1 of 1
      • Lift the battery with your fingers and pull it out.
      • You will need adhesive to reassemble the phone.
      Ask FixBot
8 other people completed this guide.
Gelene Amog
1,189 Reputation
5 Guides authored
Cal Poly, Team S18-G2, Livingston Spring 2018 Member of Cal Poly, Team S18-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G2
5 Members
72 Guides authored
4 Guide Comments
個人的意見を書きます。まず最初にこの手順はあくまでもバッテリーを取り外すだけの手順書です。作成者がこの手順書を部分的に書き直さない限り作業事故によっては「ボリューム パワースイッチフレックスケーブル」、「nfcアンテナ」、「イヤホンジャック フレックスケーブル」、最悪「マザーボード」をも交換する羽目になる事を視野に入れて作業した方がいいです。それらの注意書きがないのが残念です。
「ボリュームパワースイッチフレックスケーブル」と「nfcアンテナ」はバッテリーに接着されています。特にnfcアンテナの黒い部分は恐らくアンテナの一部と思われ奇麗に剝がそうとしても絶対に破損しますので交換必須です。
Hideo Otsuka - Reply Share
貴重なご意見、ありがとうございました。
Midori Doi - Reply Share
手順ありがとうございます。
手順25の前後でで左上側のコネクタを外す手順がなかったので見事に切りました。
他、海外動画と比較していくつか手順がすっ飛んでたので、注意書きはした方がよいと思いました。
wabi - Reply Share
詳細を報告いただきありがとうございました。手順25の前後の作業については修理ガイド担当者に付け足しの必要を伝えておきます。コネクタを破損させてしまい申し訳ありません。少し時間がかかるかもしれませんが、貴重な情報は英語と日本語の修理ガイドに反映させていただきます。御礼まで。
Past 24 Hours: 7
Past 7 Days: 68
Past 30 Days: 230
All Time: 37,874
