Sony Xperia XA2 Ultra Rear Cover Replacement
  1. Sony Xperia XA2 Ultra Rear Cover Replacement, Rear Cover: step 1, image 1 of 2 Sony Xperia XA2 Ultra Rear Cover Replacement, Rear Cover: step 1, image 2 of 2
    • Turn off your phone before continuing.
    • Remove the SIM card tray on the left side of the phone using a SIM card eject tool.
    Ask FixBot
  2. Sony Xperia XA2 Ultra Rear Cover Replacement: step 2, image 1 of 1
    • Heat the edge of the phone with the heat gun (recommended) for 30 seconds.
    • If you don't have a heat gun, a hair dryer can be used.
    • Use the hair dryer on the highest setting, constantly going around the phone to heat all of the edges.
    • The phone will become hot to the touch. Use gloves or a towel to touch the phone.
    Ask FixBot
  3. Sony Xperia XA2 Ultra Rear Cover Replacement: step 3, image 1 of 2 Sony Xperia XA2 Ultra Rear Cover Replacement: step 3, image 2 of 2
    • Apply the suction handle near an edge of the phone and pull upwards while trying to get an opening large enough for an iFixit opening pick.
    Ask FixBot
  4. Sony Xperia XA2 Ultra Rear Cover Replacement: step 4, image 1 of 2 Sony Xperia XA2 Ultra Rear Cover Replacement: step 4, image 2 of 2
    • Pry upwards with the pick to start pulling the rear cover off the adhesive it’s attached to.
    • Insert a second pick once there is enough room.
    Ask FixBot
  5. Sony Xperia XA2 Ultra Rear Cover Replacement: step 5, image 1 of 2 Sony Xperia XA2 Ultra Rear Cover Replacement: step 5, image 2 of 2
    • Take one of the picks and try to slide it down the side of the phone, pulling more of the cover off the adhesive.
    • The iFixit opening tool may also be used to gain better leverage.
    • The rear cover will pop off.
    Ask FixBot
  6. Sony Xperia XA2 Ultra Rear Cover Replacement: step 6, image 1 of 1
    • Once the rear cover is off, use the iFixit opening tool to detach the flex cable.
    Ask FixBot
Alyssa Bayles
879 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 52
All Time: 435
