Sony Xperia XA2 Ultra Battery Replacement
    1. Sony Xperia XA2 Ultra Battery Replacement, Rear Cover: step 1, image 1 of 2 Sony Xperia XA2 Ultra Battery Replacement, Rear Cover: step 1, image 2 of 2
      • Turn off your phone before continuing.
      • Remove the SIM card tray on the left side of the phone using a SIM card eject tool.
      Ask FixBot
    2. Sony Xperia XA2 Ultra Battery Replacement: step 2, image 1 of 1
      • Heat the edge of the phone with the heat gun (recommended) for 30 seconds.
      • If you don't have a heat gun, a hair dryer can be used.
      • Use the hair dryer on the highest setting, constantly going around the phone to heat all of the edges.
      • The phone will become hot to the touch. Use gloves or a towel to touch the phone.
      Ask FixBot
    3. Sony Xperia XA2 Ultra Battery Replacement: step 3, image 1 of 2 Sony Xperia XA2 Ultra Battery Replacement: step 3, image 2 of 2
      • Apply the suction handle near an edge of the phone and pull upwards while trying to get an opening large enough for an iFixit opening pick.
      Ask FixBot
    4. Sony Xperia XA2 Ultra Battery Replacement: step 4, image 1 of 2 Sony Xperia XA2 Ultra Battery Replacement: step 4, image 2 of 2
      • Pry upwards with the pick to start pulling the rear cover off the adhesive it’s attached to.
      • Insert a second pick once there is enough room.
      Ask FixBot
    5. Sony Xperia XA2 Ultra Battery Replacement: step 5, image 1 of 2 Sony Xperia XA2 Ultra Battery Replacement: step 5, image 2 of 2
      • Take one of the picks and try to slide it down the side of the phone, pulling more of the cover off the adhesive.
      • The iFixit opening tool may also be used to gain better leverage.
      • The rear cover will pop off.
      Ask FixBot
    6. Sony Xperia XA2 Ultra Battery Replacement: step 6, image 1 of 1
      • Once the rear cover is off, use the iFixit opening tool to detach the flex cable.
      Ask FixBot
    1. Sony Xperia XA2 Ultra Battery Replacement, Motherboard Bracket: step 7, image 1 of 2 Sony Xperia XA2 Ultra Battery Replacement, Motherboard Bracket: step 7, image 2 of 2
      • Remove the six 3 mm Phillips #000 screws.
      Ask FixBot
    2. Sony Xperia XA2 Ultra Battery Replacement: step 8, image 1 of 1
      • Remove the motherboard bracket with an iFixit opening tool.
      Ask FixBot
    1. Sony Xperia XA2 Ultra Battery Replacement, Speaker: step 9, image 1 of 2 Sony Xperia XA2 Ultra Battery Replacement, Speaker: step 9, image 2 of 2
      • Remove the four 3 mm screws using a Phillips #000 screwdriver.
      Ask FixBot
    2. Sony Xperia XA2 Ultra Battery Replacement: step 10, image 1 of 2 Sony Xperia XA2 Ultra Battery Replacement: step 10, image 2 of 2
      • Using an iFixit opening tool, pry and remove the speaker.
      Ask FixBot
    1. Sony Xperia XA2 Ultra Battery Replacement, Motherboard: step 11, image 1 of 1
      • Using the Jimmy, remove the two antenna flex cables.
      Ask FixBot
    2. Sony Xperia XA2 Ultra Battery Replacement: step 12, image 1 of 2 Sony Xperia XA2 Ultra Battery Replacement: step 12, image 2 of 2
      • Using the iFixit opening tool, pry and remove the motherboard.
      Ask FixBot
    1. Sony Xperia XA2 Ultra Battery Replacement, Cameras: step 13, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers to remove the rear-facing camera.
      • Use a pair of tweezers to remove the magnetic tape covering the front-facing camera.
      • Use a pair of tweezers to remove the front-facing camera.
      Ask FixBot
    1. Sony Xperia XA2 Ultra Battery Replacement, Battery: step 14, image 1 of 1
      Buy
      • Grab and twist the black battery tab with a pair of precision tweezers.
      • This will remove the adhesive that is attached to the battery.
      • Do this again with the black tab under the power button flex cable.
      Ask FixBot
    2. Sony Xperia XA2 Ultra Battery Replacement: step 15, image 1 of 2 Sony Xperia XA2 Ultra Battery Replacement: step 15, image 2 of 2
      • With the iFixit opening tool, remove the battery.
      Ask FixBot
2 other people completed this guide.
Alyssa Bayles
879 Reputation
8 Guides authored
1 Guide Comment
Do you need battery adhesive?
James McDonald - Reply Share
Past 24 Hours: 2
Past 7 Days: 36
Past 30 Days: 114
All Time: 2,068
