Sony Xperia XA1 Ultra Antenna Module Replacement
    1. Sony Xperia XA1 Ultra Antenna Module Replacement, Back Assembly: step 1, image 1 of 2 Sony Xperia XA1 Ultra Antenna Module Replacement, Back Assembly: step 1, image 2 of 2
      • Wedge your finger under the bottom ridge of the SD card insert.
      • Pull outwards with your fingers to remove the SD card from the left side of device.
      Ask FixBot
    2. Sony Xperia XA1 Ultra Antenna Module Replacement: step 2, image 1 of 1
      • Use a hair dryer to heat each corner of the phone.
      • Alternate heating each corner for a minute to loosen the adhesive binding the back cover to the phone.
      • Don't heat one area for too long; the phone may get damaged from overheating.
      Ask FixBot
    3. Sony Xperia XA1 Ultra Antenna Module Replacement: step 3, image 1 of 1
      • Press a suction cup on a heated corner of the device.
      • Hold the phone down and gently lift the suction cup to create a small gap.
      • You may hear crunching or popping sounds when you lift up the back cover.
      Ask FixBot
    4. Sony Xperia XA1 Ultra Antenna Module Replacement: step 4, image 1 of 1
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
      • Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
      Ask FixBot
    5. Sony Xperia XA1 Ultra Antenna Module Replacement: step 5, image 1 of 1
      • Slide your plastic card along the side of your phone to loosen the adhesive.
      • Move the card along the sides of the phone to lift all of the corners.
      Ask FixBot
    6. Sony Xperia XA1 Ultra Antenna Module Replacement: step 6, image 1 of 1
      • Lift up the back cover by lifting up the sides of the phone with your hand.
      • Apply a new strip of adhesive for reassembly.
      Ask FixBot
    1. Sony Xperia XA1 Ultra Antenna Module Replacement, Antenna Module: step 7, image 1 of 2 Sony Xperia XA1 Ultra Antenna Module Replacement, Antenna Module: step 7, image 2 of 2
      • Remove the four 4mm T5 screws on the top of the black panel securing the antenna module to the device.
      Ask FixBot
    2. Sony Xperia XA1 Ultra Antenna Module Replacement: step 8, image 1 of 2 Sony Xperia XA1 Ultra Antenna Module Replacement: step 8, image 2 of 2
      • Insert your iFixit Opening Tool underneath the antenna module.
      • Lift up gently with the iFixit Opening Tool to remove the antenna module.
      • The antenna module may be difficult to remove.
      Ask FixBot
Jacob Jung
1,429 Reputation
9 Guides authored
Cal Poly, Team S16-G3, Livingston Spring 2018 Member of Cal Poly, Team S16-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G3
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 63
All Time: 1,708
