Up to 20% off select tools
Sony Xperia XA1 USB-C Module Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
85
All Time:
1,114
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide is for the replacement of the USB-C module for the Sony Xperia XA1. It is common that after some time the USB-C receiver can go bad.
Before using this guide to replace the headphone jack, be sure to check out the troubleshooting page to ensure the speaker needs to be replaced.
    1. Sony Xperia XA1 USB-C Module Replacement, Phone Back Cover: step 1, image 1 of 3 Sony Xperia XA1 USB-C Module Replacement, Phone Back Cover: step 1, image 2 of 3 Sony Xperia XA1 USB-C Module Replacement, Phone Back Cover: step 1, image 3 of 3
      • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
      • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
      • Do not apply heat in one area for too long.
      Ask FixBot
    1. Sony Xperia XA1 USB-C Module Replacement, Speaker: step 2, image 1 of 3 Sony Xperia XA1 USB-C Module Replacement, Speaker: step 2, image 2 of 3 Sony Xperia XA1 USB-C Module Replacement, Speaker: step 2, image 3 of 3
      • Use a plastic opening tool to lift the battery connector.
      • Lift the flaps on both sides of the battery.
      Ask FixBot
    2. Sony Xperia XA1 USB-C Module Replacement: step 3, image 1 of 3 Sony Xperia XA1 USB-C Module Replacement: step 3, image 2 of 3 Sony Xperia XA1 USB-C Module Replacement: step 3, image 3 of 3
      • Pinch the pull tab at the bottom of the battery.
      • Gently lift the battery out.
      • Handle the battery with caution. It is very fragile.
      Ask FixBot
    3. Sony Xperia XA1 USB-C Module Replacement: step 4, image 1 of 2 Sony Xperia XA1 USB-C Module Replacement: step 4, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the four 3 mm screws that secure the bottom component.
      Ask FixBot
    4. Sony Xperia XA1 USB-C Module Replacement: step 5, image 1 of 3 Sony Xperia XA1 USB-C Module Replacement: step 5, image 2 of 3 Sony Xperia XA1 USB-C Module Replacement: step 5, image 3 of 3
      • Insert a spudger into the opening above the charging port, and apply gentle pressure to free the speaker piece.
      • Once the piece is loose, use your hand to remove the speaker from the phone.
      Ask FixBot
    1. Sony Xperia XA1 USB-C Module Replacement, USB-C Module: step 6, image 1 of 3 Sony Xperia XA1 USB-C Module Replacement, USB-C Module: step 6, image 2 of 3 Sony Xperia XA1 USB-C Module Replacement, USB-C Module: step 6, image 3 of 3
      • Locate the connecting cable and use a spudger or iFixit Opening Tool to remove the connector.
      • Disconnect the wifi/Bluetooth antenna wire, located at the top right of the USB-C charger board.
      Ask FixBot
    2. Sony Xperia XA1 USB-C Module Replacement: step 7, image 1 of 3 Sony Xperia XA1 USB-C Module Replacement: step 7, image 2 of 3 Sony Xperia XA1 USB-C Module Replacement: step 7, image 3 of 3
      • After removing the connector and antennas, you are able to pry the USB-C board using a plastic spudger.
      • Be cautious, little effort is required to lift up the board, if too much force is applied this could damage the board.
      Ask FixBot
Author
with
sebastianh034
253 Reputation
3 Guides authored
1 Guide Comment
thanks a lot, super clear, done everything in ~10 minutes
Eugene - Reply Share
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 85
All Time: 1,114
