Sony Xperia XA1 Screen Replacement
    1. Sony Xperia XA1 Screen Replacement, Phone Back Cover: step 1, image 1 of 3 Sony Xperia XA1 Screen Replacement, Phone Back Cover: step 1, image 2 of 3 Sony Xperia XA1 Screen Replacement, Phone Back Cover: step 1, image 3 of 3
      • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
      • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
      • Do not apply heat in one area for too long.
      Ask FixBot
    1. Sony Xperia XA1 Screen Replacement, Speaker: step 2, image 1 of 3 Sony Xperia XA1 Screen Replacement, Speaker: step 2, image 2 of 3 Sony Xperia XA1 Screen Replacement, Speaker: step 2, image 3 of 3
      • Use a plastic opening tool to lift the battery connector.
      • Lift the flaps on both sides of the battery.
      Ask FixBot
    2. Sony Xperia XA1 Screen Replacement: step 3, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 3, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 3, image 3 of 3
      • Pinch the pull tab at the bottom of the battery.
      • Gently lift the battery out.
      • Handle the battery with caution. It is very fragile.
      Ask FixBot
    3. Sony Xperia XA1 Screen Replacement: step 4, image 1 of 2 Sony Xperia XA1 Screen Replacement: step 4, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the four 3 mm screws that secure the bottom component.
      Ask FixBot
    4. Sony Xperia XA1 Screen Replacement: step 5, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 5, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 5, image 3 of 3
      • Insert a spudger into the opening above the charging port, and apply gentle pressure to free the speaker piece.
      • Once the piece is loose, use your hand to remove the speaker from the phone.
      Ask FixBot
    1. Sony Xperia XA1 Screen Replacement, USB-C Module: step 6, image 1 of 3 Sony Xperia XA1 Screen Replacement, USB-C Module: step 6, image 2 of 3 Sony Xperia XA1 Screen Replacement, USB-C Module: step 6, image 3 of 3
      • Locate the connecting cable and use a spudger or iFixit Opening Tool to remove the connector.
      • Disconnect the wifi/Bluetooth antenna wire, located at the top right of the USB-C charger board.
      Ask FixBot
    2. Sony Xperia XA1 Screen Replacement: step 7, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 7, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 7, image 3 of 3
      • After removing the connector and antennas, you are able to pry the USB-C board using a plastic spudger.
      • Be cautious, little effort is required to lift up the board, if too much force is applied this could damage the board.
      Ask FixBot
    1. Sony Xperia XA1 Screen Replacement, Screen: step 8, image 1 of 3 Sony Xperia XA1 Screen Replacement, Screen: step 8, image 2 of 3 Sony Xperia XA1 Screen Replacement, Screen: step 8, image 3 of 3
      • Using a spudger, carefully remove the thin copper piece attached to the motherboard.
      • This part is very easy to damage and can not be reused if damaged too much.
      Ask FixBot
    2. Sony Xperia XA1 Screen Replacement: step 9, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 9, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 9, image 3 of 3
      • Carefully remove the front-facing camera with a spudger or your fingers.
      Ask FixBot
    3. Sony Xperia XA1 Screen Replacement: step 10, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 10, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 10, image 3 of 3
      • Remove the single 3mm screw holding the audio jack using a Phillips #000 bit.
      • Using an iFixit Opening Tool, disconnect the audio jack from the motherboard.
      • Use a prying tool, such as a spudger, to remove the audio jack.
      Ask FixBot
    4. Sony Xperia XA1 Screen Replacement: step 11, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 11, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 11, image 3 of 3
      • Disconnect the camera using an iFixit opening tool and remove it with your fingers.
      Ask FixBot
    5. Sony Xperia XA1 Screen Replacement: step 12, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 12, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 12, image 3 of 3
      Tool used on this step:
      Buy
      • Disconnect the two antennas from the motherboard using an iFixit opening tool or pair of tweezers.
      Ask FixBot
    6. Sony Xperia XA1 Screen Replacement: step 13, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 13, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 13, image 3 of 3
      • Remove the SIM tray using your fingernail.
      • Using a spudger, remove the two connector tabs attached to the motherboard
      Ask FixBot
    7. Sony Xperia XA1 Screen Replacement: step 14, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 14, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 14, image 3 of 3
      • Remove the single 3mm screw from the motherboard using a Phillips #000 bit.
      • Use a spudger to gently pry the motherboard free.
      Ask FixBot
    8. Sony Xperia XA1 Screen Replacement: step 15, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 15, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 15, image 3 of 3
      • Peel the plastic battery tabs free.
      Ask FixBot
    9. Sony Xperia XA1 Screen Replacement: step 16, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 16, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 16, image 3 of 3
      • Using a pair of angled tweezers, carefully remove the earpiece.
      • The ear piece is attached using a sticky adhesive
      Ask FixBot
    10. Sony Xperia XA1 Screen Replacement: step 17, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 17, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 17, image 3 of 3
      • Using a pair of angled tweezers, carefully remove the small metal bracket from the top left side of the phone.
      Ask FixBot
    11. Sony Xperia XA1 Screen Replacement: step 18, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 18, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 18, image 3 of 3
      • Remove the four 3mm silver screws located on the left side of the case using a Phillips #000 bit.
      • Once the screws are removed, unfold the side piece.
      Ask FixBot
    12. Sony Xperia XA1 Screen Replacement: step 19, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 19, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 19, image 3 of 3
      • Using a pair of angled tweezers, remove the power and volume buttons.
      Ask FixBot
    13. Sony Xperia XA1 Screen Replacement: step 20, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 20, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 20, image 3 of 3
      • Carefully remove the antennas.
      • Use a pair of tweezers if needed.
      Ask FixBot
    14. Sony Xperia XA1 Screen Replacement: step 21, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 21, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 21, image 3 of 3
      • Remove the four 3mm silver screws from the right side of the phone using a Phillips #000 bit.
      • Once unfolded, peel the side piece from the phone, separating the glue that holds the two pieces together.
      Ask FixBot
    15. Sony Xperia XA1 Screen Replacement: step 22, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 22, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 22, image 3 of 3
      • Remove the other side in the same manner.
      • All removeable components should be free, ready to be installed into your replacement screen.
      Ask FixBot
Hunter
349 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 79
All Time: 1,101
