Sony Xperia XA1 Rear Camera Replacement
    1. Sony Xperia XA1 Rear Camera Replacement, Phone Back Cover: step 1, image 1 of 3 Sony Xperia XA1 Rear Camera Replacement, Phone Back Cover: step 1, image 2 of 3 Sony Xperia XA1 Rear Camera Replacement, Phone Back Cover: step 1, image 3 of 3
      • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
      • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
      • Do not apply heat in one area for too long.
      Ask FixBot
    1. Sony Xperia XA1 Rear Camera Replacement, Rear Camera: step 2, image 1 of 3 Sony Xperia XA1 Rear Camera Replacement, Rear Camera: step 2, image 2 of 3 Sony Xperia XA1 Rear Camera Replacement, Rear Camera: step 2, image 3 of 3
      • Use a Phillips #000 screwdriver to remove the three 3 mm screws near the top of the phone.
      • Use a spudger to gently pry the three tabs at the top of the phone.
      Ask FixBot
    2. Sony Xperia XA1 Rear Camera Replacement: step 3, image 1 of 3 Sony Xperia XA1 Rear Camera Replacement: step 3, image 2 of 3 Sony Xperia XA1 Rear Camera Replacement: step 3, image 3 of 3
      • Gently pry at the tabs until the cover comes free and is able to be removed.
      • Pull the piece up and set it aside. No cables are attached to the back.
      Ask FixBot
    3. Sony Xperia XA1 Rear Camera Replacement: step 4, image 1 of 3 Sony Xperia XA1 Rear Camera Replacement: step 4, image 2 of 3 Sony Xperia XA1 Rear Camera Replacement: step 4, image 3 of 3
      • Use an opening tool to release the back camera connector.
      • Gently pull the camera connector up to remove it.
      • Exercise caution when handling the rubber holder around the lens, as it can pop off easily.
      Ask FixBot
sebastianh034
253 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 36
All Time: 447
