Up to 20% off select tools
Sony Xperia XA Ultra Vibrator Module replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
80
All Time:
990
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 40 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the vibrating module of the Sony Xperia XA Ultra, in the event that the device's vibrating capabilities are weakened or stop working completely. To complete this guide, you will need a t3 and t5 torx screw driver, as well as a plastic spudge or wedging tool of some kind.
    1. Sony Xperia XA Ultra Vibrator Module replacement, Motherboard: step 1, image 1 of 2 Sony Xperia XA Ultra Vibrator Module replacement, Motherboard: step 1, image 2 of 2
      • Carefully remove the back panel of the phone with a plastic spudger, or other flat and thin wedge tool. Work your way around the perimeter of the case, loosening and prying gently, until there is sufficient distance between the panel and phone.
      Ask FixBot
    2. Sony Xperia XA Ultra Vibrator Module replacement: step 2, image 1 of 2 Sony Xperia XA Ultra Vibrator Module replacement: step 2, image 2 of 2
      • Remove all 9 black 4mm T5 screws.
      • Remove all 8 silver 3mm T3 screws.
      • Make sure to carefully place each screw in a secure location to avoid losing any.
      Ask FixBot
    3. Sony Xperia XA Ultra Vibrator Module replacement: step 3, image 1 of 3 Sony Xperia XA Ultra Vibrator Module replacement: step 3, image 2 of 3 Sony Xperia XA Ultra Vibrator Module replacement: step 3, image 3 of 3
      • Near the top of the battery (area closest to camera) press the small latch in the highlighted area, push the latch away from the metal casing with the metal spudger.
      • Use the plastic opening tool to pry off the metal case. Be sure to carefully pry the casing slowly and at multiple angles and directions to insure nothing is damaged.
      • Be careful when prying near the top of the device. The metal casing can be easily bent.
      Ask FixBot
    4. Sony Xperia XA Ultra Vibrator Module replacement: step 4, image 1 of 2 Sony Xperia XA Ultra Vibrator Module replacement: step 4, image 2 of 2
      • Remove the side bezels from each side, and remove the sim card cover.
      Ask FixBot
    5. Sony Xperia XA Ultra Vibrator Module replacement: step 5, image 1 of 2 Sony Xperia XA Ultra Vibrator Module replacement: step 5, image 2 of 2
      • Using the plastic opening tool, gently pry off the black charge port plate, located near the bottom of the phone.
      • Remove the sim card from sim card slot using fingernail or small plastic spudger.
      Ask FixBot
    6. Sony Xperia XA Ultra Vibrator Module replacement: step 6, image 1 of 3 Sony Xperia XA Ultra Vibrator Module replacement: step 6, image 2 of 3 Sony Xperia XA Ultra Vibrator Module replacement: step 6, image 3 of 3
      • Disconnect all four of the shown electrical connectors by gently prying up with the plastic opening tool.
      Ask FixBot
    7. Sony Xperia XA Ultra Vibrator Module replacement: step 7, image 1 of 2 Sony Xperia XA Ultra Vibrator Module replacement: step 7, image 2 of 2
      • Working from bottom to top, gently pry the motherboard off of the phone .
      • The camera is connected to the motherboard. Be extremely careful when removing it to avoid damage.
      Ask FixBot
    1. Sony Xperia XA Ultra Vibrator Module replacement, Vibrator module: step 8, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to pull the vibrator module out of its socket.
      • Since the vibrator module is glued in place we recommend applying a low-level heat source to loosen the glue.
      • Be sure not to let the vibrator module become too hot to touch.
      • If using metal tweezers be careful not to touch any other phone components.
      Ask FixBot
2 other people completed this guide.
Author
with
Walter Lackey
419 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 80
All Time: 990
